Old 05-17-2007, 01:55 PM   #1
IWSTI Addict since: Feb 2004
Default What should I get first? Springs or Swaybars?
After getting a TBE finally installed, my next goal is to make my car more competent in the handling department. I am getting more and more into AutoXing, but my car IS still a daily driver. Alas, I can't go insane with the setup.
I'm at a crossroads now on whether to install springs or swaybars first. For springs, I was thinking of going with the Prodrives and Sways, Whiteline 24-26mm fronts and 24 adjustable rears. What do you guys think I should do first? I've been reading and reading about how aggressive sways (I guess 24-26 isn't TOO aggressive) and stock springs don't mix well. But how sways is pretty much the best bang-for-your buck upgrade you can get. Will the my sway setup clash with my stock springs?
If the answer is yes, perhaps I should go with springs first then?
What do you guys all think?
volkl23 is offline   Reply With Quote
Old 05-17-2007, 02:01 PM   #2
IWSTI Addict since: Mar 2006
Default Re: What should I get first? Springs or Swaybars?
Sways. Trim your stock bump stops to "improve" your springs.
stretch is online now   Reply With Quote
Old 05-17-2007, 02:04 PM   #3
Fav Mod: Ohlins struts
IWSTI Addict since: Oct 2006
Well, I'd be tempted to wait for the new RCE "regular guy" springs for your purposes. They'll produce a very mild drop but will have a higher spring rate than the Prodrives.
As for using Whiteline sway bars with stock springs, I'll find out how that combo works very soon. I'll be installing my sway bars Saturday.
SWortham is offline   Reply With Quote
Old 05-17-2007, 02:05 PM   #4
Nice! Can't wait for the review. Which ones did you get?
Old 05-17-2007, 02:06 PM   #5
I'm a noob when it comes to suspension.. Can you further elaborate?
Old 05-17-2007, 02:08 PM   #6
24mm front / 24mm rear Whitelines. I plan on setting the front to full stiff, and the rear to the middle setting. I also have Ohlins struts and RCE lowering camber plates so it won't be a perfect comparison to what you should expect, but we'll see.
The one thing you'll continue to have with the stock springs is perhaps more brake dive than you'd like, but these sway bars should provide quite an improvement in roll stiffness.
Old 05-17-2007, 02:26 PM   #7
Car: '04.5 STi
IWSTI Addict since: Apr 2006
Swaybars, definitely.
Old 05-17-2007, 03:02 PM   #8
Car: 06 sti
Fav Mod: the next one
i'm running the same whiteline sways your suggesting and they work great with the stock springs, the car handles much better. though i just recived my pinks the other day and am waiting for some prodrive bump stops to get here. so things are about to change but i can only think for the better.
stephen powers is offline   Reply With Quote
Old 05-17-2007, 03:03 PM   #9
IWSTI Addict since: May 2005
Definitely get the swaybars first. they make a huge difference. best bang for the buck.
Lang is offline   Reply With Quote
Old 05-17-2007, 03:47 PM   #10
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
this is exactly the route I took (and AFAIK Im the only one on stock springs with short bumpstops here). check for threads started by me in here, and also the bumpstops thread started by stretch.
Old 05-17-2007, 04:02 PM   #11
Car: Stage 2 05 OBP STi
Fav Mod: Hotkchis sway bar kit
IWSTI Addict since: Dec 2004
i went with sways and shortly after went with springs and really did not notice too much other than lower and less of a bouncy ride other than large bumps.
blacknight is offline   Reply With Quote
Old 05-17-2007, 04:26 PM   #12
Fav Mod: Garrett Turbo
IWSTI Addict since: Aug 2004
Anyone have a good website/vendor to get whiteline sway bars for chheaap from?
oce420 is offline   Reply With Quote
Old 05-17-2007, 04:41 PM   #13
He ships VERY fast.
http://turninconcepts10.chainreactio...c5b521adcae364
Old 05-17-2007, 04:58 PM   #14
Car: 05 STi Silver
Fav Mod: Rumble + Torque = COBB Stg2
IWSTI Addict since: Aug 2005
Your on the right track wanting sways and springs. Prodrive springs and whiteline sways should be awesome.
For me, it was whenever I could find a deal on either, I like checking ebay and iwsti for deals. So I ended up doing jdm pinks first and COBB sways are on the way.
Kirv is offline   Reply With Quote
Old 05-18-2007, 05:33 AM   #15
Car: 05 Blue/Gold
Fav Mod: Blinker Fluid and Piston Return Springs
I've been daily driving with the Whiteline 27-29 front and 24-26 rear for more than a year now. I have stock springs and both bars set to full stiff. The ride has been fine. I also have a set of RCE T2's on the way.
Subaru of Gwinnett is also a good source for the Whiteline bars. That's where I ordered mine.
IlliniSTi is offline   Reply With Quote
