Old 05-08-2007, 09:27 AM   #1
IWSTI Addict since: Oct 2005
Default BILSTEIN PSS9 Review
First note, these are some very nice coilovers.
Installation was a breeze. They work with stock top hats. The only thing to note is the bottom of the assembly comes very very close to the axle boot.. (less than 1/8 inch) which makes me a little nervous, but they did fit.
I first set them on the softest setting. You can tell that on soft, the ride is still stiffer than stock but very comfortable for daily driving. After a day of driving I set it to as stiff as it would go. At a very stiff level, the car seems to bounce a little, but still very comfortable. Im going to back it down to a setting of 4 and be done with it.
Overall, I am very pleased, and the cars handling is simply amazing now with a comfortable ride to boot. I would highly recommend these if you have the money to buy them.
siusti is offline   Reply With Quote
Old 05-08-2007, 11:20 AM   #2
Fav Mod: T2s and Recaros
Default Re: BILSTEIN PSS9 Review
Thanks for the review! When you say "at a very stiff level" are you on the stiffest setting?
Old 05-08-2007, 11:25 AM   #3
Car: 07 Sti SWP
IWSTI Addict since: Mar 2007
Any unusual noises ie clunks?
wrinklefree is offline   Reply With Quote
Old 05-08-2007, 12:01 PM   #4
Yes: Level 1
Old 05-08-2007, 12:02 PM   #5
Nothing yet
Old 05-08-2007, 12:12 PM   #6
Car: 08 STi, SSM
IWSTI Addict since: Dec 2005
So you're saying the bottom spring perch comes close to the axle boot?
Old 05-08-2007, 12:15 PM   #7
IWSTI Addict since: Mar 2006
It comes pretty close even on a stock strut. No big deal, it's just tight in there.
Old 05-08-2007, 12:16 PM   #8
the absolute bottom of the assembly (where the adjustment knob is) is about 1/8th of an inch away from the axle boot. it will never touch the axle boot because of the configuration of the suspension as a whole, but still..
Old 05-08-2007, 12:18 PM   #9
Car: 08 STi, SSM
gotcha, i was having trouble imagining what was coming so close, I forgot about the adjuster. I've seen people with JICs move the body of the strut low enough to push the adjuster into the axle boot.
Old 05-08-2007, 04:19 PM   #10
cpa
IWSTI Addict since: Oct 2003
Did you install these with camber plates, and if so which ones? Do you still have the Cobb swaybars (hollow bars at 25MM same as the Hotchkis?) listed in your signature with these?
How would you describe the handling and do you auto-X or track the car or run other than street tires?
cpa is offline   Reply With Quote
Old 05-08-2007, 05:24 PM   #11
I didn't camber plates.
I have the Cobb hollow bars.
The handling is remarkably tight. My car doesn't move when you shove it.. only the tires lean a little. I'm going autocrossing this weekend if I can figure out my WOT misfire problem.
BTW.. I had Eibach Sportlines with stock struts before as a comparison.
So far around town the suspension feels great through corners and curvy roads.
Old 05-08-2007, 10:34 PM   #12
Car: Black 05 WRX STI
IWSTI Addict since: Nov 2006
when you had them on full soft. were they as bouncy as stock? or were they smoother than stock? im seriously considering this coilover but just want to know if it can serve as a better daily driver on softer settings.
danchon is offline   Reply With Quote
Old 05-08-2007, 11:58 PM   #13
Car: 2007 SWP STI
I've got some PSS9s in my garage waiting for RCE camber plates, mounts and some other goodies. Any pics during or after the install? I haven't performed a suspension swap-out in years and any pictures are helpful.
jsmithjr732 is offline   Reply With Quote
Old 05-09-2007, 07:45 AM   #14
it was about the same as stock.. maybe a tad bouncy
Old 05-09-2007, 07:46 AM   #15
sorry didn't take any pictures.
its an easy swap
