Old 05-08-2007, 07:02 AM   #1
Car: '06 Aspen White STI
Fav Mod: RCE Tarmac 2
IWSTI Addict since: Jul 2006
Default Thunking noises after ALK install
I installed a Whiteline Sport ALK a couple weeks ago ago and since then, I have been hearing thunking/thudding noises coming from the front end when I drive over uneven pavement or when I approach speed bumps. The noises are coming from the ALK/lower chasis area. Is it normal to get this type of noise or did I install the ALK incorrectly?
Drag-On is offline   Reply With Quote
Old 05-08-2007, 08:59 AM   #2
Car: 2006 - CGM
IWSTI Addict since: Nov 2005
Default Re: Thunking noises after ALK install
No. I'd get under there with a torque wrench and re-torque all the bolts (3 per side). Repeat after 1000 miles even if its quiet.
Old 05-08-2007, 09:01 AM   #3
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
do you have an h-brace? if so, do some more searching, metal may be contacting down there. i saw a thread about it once.
Old 05-08-2007, 09:14 AM   #4
I will give that a try. I know that this mod adds NVH but I grew suspicious when I started to hear unusual thunking noises.
No I don't have an H-brace. My subframe is currently stock.
Old 05-08-2007, 10:30 AM   #5
jph
Car: the wagon
IWSTI Addict since: Apr 2004
mine are dead silent, so something is not right.
sorry, can't be of any more help than that
J.
Old 05-08-2007, 10:44 AM   #6
Car: 06 OBP STi
IWSTI Addict since: Sep 2005
Same here absolutely silent...although my struts make noises when they hit the bumpstops... nothing some RCE T2's in the next week or so will fix though!
Again, just get down there and torque those bolts down to spec...also, be sure to put a good amount of grease on them to help keep them silent.
Kind Regards,
Ryan
r12rex is offline   Reply With Quote
Old 05-13-2007, 10:09 AM   #7
It turns out that the person that helped me install it flipped the ALK when installing it. The bottom side was facing up and the top side was facing down. I reinstalled everything and there is no more tapping/thunking noises anymore.
Old 05-13-2007, 12:03 PM   #8
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Well...that would explain the thunk
polyol is online now   Reply With Quote
