| STI Driver Car: 06 Sti/White Fav Mod: APS FMIC/HarmanMotive tune Location: Orange County, Ca Posts: 214
IWSTI Addict since: Feb 2006 Trader Rating: (0) | Myles? anyone? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,864
IWSTI Addict since: Mar 2006 Trader Rating: (2) | The point of buying Motons (or any super expensive, super adjustable coilover product) is that you can make them however you want them to be. |
| | #4 |
| Sold My Soul For Mods Car: '05 CGM STi Fav Mod: Track Time Location: Bethesda, MD Posts: 6,688
IWSTI Addict since: Jun 2004 Trader Rating: (14) | Give Myles a call, he's used them before. We also have a couple cars that we sponsor that are using Moton Clubsports but I believe they are all Evos. |
| | #5 |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | I spent awhile staring at the Motons. In the end, I liked the Ohlins Flag static high speed compression, and wanted to keep my adjustments to lower-speed compression and all of rebound. That being said, I now would potentially put a bit of "weight" onto non-inverted rear dampeners. I don't recall if the Motons are inverted or not in the rear, but Im coming to the conclusion that its very hard to get inverted struts to behave happily long-term with the angles of a GD rear Subaru. I've been working with Ohlins on my minor binding issue in the rear of my Flags, and it has no current effect on performance. Just a minor clunk in the back in certain conditions on the street. There are a number of folks doing great valving for Evos for the Flags... I don't know that expertise is available with the Motons... and we have Subies anyways. |
| | #6 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | I don't understand- inverted struts should be stronger. If something inherent in the suspension is causing inverted struts to bind, it should be happening twice as badly on a non-inverted strut. Monotubes (inverted or not, but moreso on inverted) have higher static friction than hydrolic dampers, but that is independent of suspension geometry. |
| | #7 | |
| Authorized Vendor | Quote:
It's actually a lube issue between the damper housing, and the packaging housing. It's pretty common on inverted setups. | |
| | #8 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Right, I only meant to say that I don't think the problem can be attributed to Subaru-specific suspension geometry. |
| | #9 |
IWSTI Addict since: Jun 2004 Trader Rating: (14) | It can though in a way because the rear struts are mounted at a slight angle. Although most of the force is being applied vertically when the shock is compressed, due to the angle there is a small amount of lateral force as well. This can break down lubrication between the shaft and the housing over time. Some companies have managed to achieve proper lubrication, like Ohlins (which is why fixed perch don't clunk), but even they have the occasional issue like in RainMaker's case. |
| | #11 | |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,412
IWSTI Addict since: Apr 2005 Trader Rating: (10) | Quote:
We helped Moton develop thier STi and EVO applications. - Andrew | |
| | #12 | |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
| | #13 | |
IWSTI Addict since: Jun 2004 Trader Rating: (14) | Quote:
| | #14 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Very true- heck, I can only think of Porsches that still use struts in the back. But still, the front of the car has more weight on it, mounts the strut at a more extreme angle, and has to cope with higher spring and damper rates. If anything stresses a strut, it'd be the front. |
| | #15 |
IWSTI Addict since: Jun 2004 Trader Rating: (14) | Yeah, I didn't say it necessarily makes sense to me but that's just the way it is. I've never seen a front strut develop clunking but rears do it all the time. This ad is not endorsed by this member. Please register or login to hide this ad. |
