Old 05-02-2007, 12:29 AM   #1
aka: jnprn2003
Fav Mod: EFI Logics tunage
IWSTI Addict since: Feb 2007
Trader Rating: (13)
Default Next chassis mods???
Hey all,
I have done a search to only find some answers...I want to improve the handling and increase the stiffness of my car. I am not sure of what to do next. There are so many bushings and bars I am not sure of the next few mods should be or what works. I want to keep the costs around $1000 and I will be performing the labor.
I currently have for suspension mods:
H&R lowering springs 1.3R, 1.4F
Cobb front and rear sway bars
Cobb front and rear endlinks
Cobb tranny mount
Things I am looking at:
Beatrush rear diff support bar
Front 4 point ladder brace
Front and rear strut tower braces
Crossmember bushings
Rear diff. bushings
Beatrush propeller shaft bushings
Front camber plates OR Group N tops?
Whiteline steering rack bushings
Any other suggestions...?
I want to get the best bang for my buck.
Joe
RONIN is offline   Reply With Quote
Old 05-02-2007, 04:09 AM   #2
Car: 04 PSM STi
IWSTI Addict since: May 2003
Default Re: Next chassis mods???
The bushings will give you best bang for the buck, since they are relatively inexpensive. If you want stiff, forget the strut tower braces and get a Carlabs X-brace for the rear and a RPM subframe brace for the front. Oh, and maybe some fender braces too.
wi77iam is offline   Reply With Quote
Old 05-02-2007, 05:30 AM   #3
nulla poena sine lege
Car: '08 GT500
IWSTI Addict since: Nov 2003
depending on cost:
fender cowl braces
CarLabs X-Brace
RCE front camber plates (or buy my Cusco for $105 used )
RPM front subframe
Then get the cheap stuff like bushings etc
QuickSilverSTi is offline   Reply With Quote
Old 05-02-2007, 08:45 AM   #4
Car: 05 WRX STi
IWSTI Addict since: Apr 2005
How about a roll cage? That will stiffen the car up very fast without all the other mods.
You can get a 6 point for under a thousand. You will be sure to notice the difference.
Old 05-02-2007, 08:50 AM   #5
Car: '08 GT500
and need a helmet to drive it on the street...
Old 05-02-2007, 11:07 AM   #6
Fav Mod: FYI, I'm a dude
IWSTI Addict since: Mar 2005
i agree w/ quicksilver. i also suggest an alk (i.e. from whiteline) and stiffer engine mounts (i.e. cusco or group-n). a front strut bar really isn't needed as you will see little performance gains.
Old 05-02-2007, 11:09 AM   #7
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
camber plates in the front, group n mounts in the rear
xbrace
alk
subframe brace
i feel like the other stuff is just suspension bling for a street car
