Old 05-01-2007, 09:56 AM   #16
Car: '05 CGM STi
IWSTI Addict since: Nov 2004
Default Re: Best Camber Plates?
Originally Posted by SmoothSTi
I've got PDE's for my coilovers (lowering isn't an issue with height adjustment) and the pre-drilled holes make going from my track/auto-x setup to my street setup VERY easy. If you don't want to run aggressive camber all the time, this is the way to go.
No camber plates yet made actually allow for what you are doing. Changing the camber drastically changes toe. So unless you are adjusting toe when you adjust your plates you'll either have toe in or toe out problems.
Old 05-01-2007, 10:00 AM   #17
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
IWSTI Addict since: Jun 2004
Trader Rating: (14)
That's very true. Some auto-x guys have their street settings at modest camber and 0 toe and when they dial in more camber, they get some toe out, which is a good thing (for most people). However, I would never put my car on a road course at high speed without knowing my alignment was exactly where I wanted it.
Old 05-01-2007, 10:38 AM   #18
Car: 05, Subaru Impreza W
IWSTI Addict since: Oct 2005
I went from -.75 camber to -1.75 camber in the front with camber plates and my toe didn't appear to change...at least based on my measurements. Perhaps that isn't considered drastic??
BlueGold is offline   Reply With Quote
Old 05-01-2007, 10:41 AM   #19
Car: 2006 - CGM
IWSTI Addict since: Nov 2005
1.0 degree of negative camber is good for about 1/4 inch of toe-out. At least according to Darrin at West End, if that means anything. I know CGMDan got quite a bit more than that, so YMMV.
Old 05-01-2007, 10:45 AM   #20
IWSTI Addict since: Mar 2006
Originally Posted by twiSTies
will they bolt up to the bilsteins? the bilsteins use the stock diameter.
I don't know. The GC camber plates say for 2.5" inner diameter coilovers. I really don't see any difference between GC design tophats and other coilovers, so I suspect they will work.
http://www.ground-control-store.com/...p/II=150/CA=90
Old 05-01-2007, 10:48 AM   #21
Interesting....I guess I better double check mine although it drives just fine on the expressway. It was my understanding that lowering is what really throws your toe off?
Old 05-01-2007, 10:50 AM   #22
Car: '05 CGM STi
Unfortunatly I don't remember exactly what it was but it was something like 0.5 deg toe change for every 1 deg camber change, per side. I'll have to get it back in the shop and actually take notes this time.
Regardless of the exact change, it was enough to convince me you wouldn't want to do it like that.
Old 05-01-2007, 10:56 AM   #23
IWSTI Club Level 1
Car: The Spaze Mobile
Fav Mod: Tuning
IWSTI Addict since: Jan 2006
Pde and RCE are both good. It just depends on if you wanna have a castor adjustment. If you do get the PDE's.
Old 05-01-2007, 11:02 AM   #24
Car: '05 CGM STi
OK so I just got off the phone with my alignment guy. Sounds like both Greg and myself are in agreement. a toe change of .25 inch = .5 degree.
And this is just on one side. I don't think a total of 1 degree of toe out is a good thing in anyones book.
Back on subject.
RCE's and PDE's are both good plates. I obviously have the RCE's. But if they weren't avalable I would have picked up the PDE's.
Old 05-01-2007, 12:38 PM   #25
Car: 2006 - CGM
Darrin set a friends car up as follows.
  • RCE lowering plates set to full negative, camber bolt adjusted to provide -2.5 degrees of camber. Toe not set at this point.
  • RCE plates pulled back to provide -1.5, then toe set to 0.
  • Plates repositioned to -2.5 - total toe-out measured to be .25 (both sides)
I realize this is far less toe out than you were seeing, which why I added the YMMV.
Old 05-02-2007, 07:38 PM   #26
Fav Mod: Starving my STI
IWSTI Addict since: Sep 2006
Trader Rating: (15)
I have a CARBING strut brace so the GC ones are out. I guess it's down to PDE and RCE.
