| STI Driver Car: 2006 Subie STi Fav Mod: Turbo-back exhaust Location: Clarksville, Tn Posts: 214
IWSTI Addict since: Apr 2007 Trader Rating: (0) | Does anyone have the Perrin Positive Steering Response Kit. Is it a pain to install? Ive had it in my trunk for a while and wondering if I should get in gear and put these things on. Can you feel a big difference with them? Just wondering if its worth it. Thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Silver Member Car: 2006 - CGM Location: Western Washington Posts: 828
IWSTI Addict since: Nov 2005 Trader Rating: (0) | The Whiteline version is more popular here. It was their idea and others, including Perrin copied them. Its similar, but as I recall the Perrin had some issues with clunking. Search on ALK and you will find tons of good info including impressions, and installation comments. If your Perrin verison is not the one with the issues, its highly recommended. |
| | #3 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | Cool, thanks. I will look into that. They just seem like a pain in the a** to install. Plus Im going to have to pay for a alignment after I put them in! Bummer for my wallet! |
| | #4 |
| Spec C Club
Car: 05 GT30R STI Fav Mod: HKS Kansai Diffuser Location: C.A. Posts: 1,157
IWSTI Addict since: Aug 2004 Trader Rating: (8) | Whiteline's ALK is not simply better due to its popularity. They are superior because the bushings are actually angled as opposed to Perrin's PSRS & GT Specs ALK where the bushing was just stamped in w/o angle. |
| | #9 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | Did you get an alignment after you installed it? Does this affect bump steer at all? I have horrible bump steer! Anyone else? My suspention is stock except Front and rear Perrin swaybars. Ive had this problem before the Swaybar install... I figured this kit might help. I will have acess to power tools so I think it should go well. I was just wondering about the drive from the shop to and a alignment shop. Thanks fo the input, very very useful! |
| | #10 |
IWSTI Addict since: Nov 2005 Trader Rating: (0) | ^^^ You'll need an alignment after the ALK, yes. Bumpsteer, no. Changing caster alot (ALK changes it by a small amount) , or significantly lowering the car will give you more bumpsteer. If you are stock, except sways, you may not be experiencing bump steer. |
| | #11 |
| Spec C Club
IWSTI Addict since: Aug 2004 Trader Rating: (8) | Feels great after the ALK install though, worth the time although I didn't do it myself. I don't think I want to do all that in my driveway. |
| | #12 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | I dont know, I hit small bumps and my car wants to take quick turns left or right. Thats bump steer, correct? Mostly at low speeds. Its kind of a pain fighting the steering wheel all the time. Maybe its the tires cuz, of the side wall. TIMELESS how much did it cost for you to get them installed? If it out wieghs the pain for installing them myself I might go that route! Thanks again! |
| | #13 | |
IWSTI Addict since: Nov 2005 Trader Rating: (0) | Quote:
What you are describing sounds more like the steering wheel kickback when you hit an obstruction or road imperfection with one wheel and not the other. The imbalance of pressure on the two tires causes more drag one side, which is felt in the steering wheel. A simlar thing would happen if you had a radical difference in tire pressure between the two front tires. The car would pull to one side. The following two charts (courtesy of Nick) show the how the toe is affected by suspension travel on a stock STI (an 04 iirc) vs an STI with more caster. As you can see, the toe changes are fairly small until you get out to the extremes. You can also see the affects addtional caster causes on bumpsteer. Note that the 07s have less caster, and will likely have less bumpsteer. (links to charts removed) Last edited by Greg; 05-11-2007 at 03:07 PM. | |
| | #14 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | Thanks for the info. I guess thats just how the car drives. My tire pressure are the same for the front. I guess I wil have to deal with it and keep both hands on the wheel! Thanks again!! |
| | #15 | |
| S204 Racer Car: 2006 STI Fav Mod: Recaros Location: Mahan, OR Posts: 2,904
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Quote:
