| | #16 |
| Professional STI Racer
Car: 02 Penis Extender Fav Mod: Autotrader.com Location: Philly Posts: 822
IWSTI Addict since: Jan 2006 Trader Rating: (1) | 6gun racing sells beefy bearings for the front, but nothing for the back yet. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #18 |
IWSTI Addict since: Jan 2006 Trader Rating: (1) | I think they are the same as the 05 bearings, just made to fit an 04 knuckle. |
| | #19 |
| Junior STI Driver Car: 04 Subaru WRX STi Fav Mod: Coming Soon Location: Fort Collins, CO Posts: 66
IWSTI Addict since: Oct 2005 Trader Rating: (0) | Is the problem the bearing or the hub? I have experienced brake problems that I believe are brake pad knock back, which is caused by flexing of the hub. Will replacing only the bearing fix this problem? How big of a deal is it to replace the hubs? |
| | #20 |
| Amateur STI Driver | I have the brake knock back also. I believe it is "normal" for the car, but I have also heard that the pad knock back is also a symptom of bad bearings. I guess going to the 6gun 5x100 with '04 strut purch is probably the way to go if the car is going to be on the track. Atleast they will be easier to change that way. |
| | #21 |
| Professional STI Driver Car: 2004.5 STi Fav Mod: Driving School Location: Toronto Posts: 486
IWSTI Addict since: Aug 2003 Trader Rating: (0) | Well i think all the sti knockback slightly, 04's just do it more...and it gets worse and worse with abuse. 6GUN sells the 04-->05 hub conversion kit. You'll be using 05 hubs and will need an 05 front strut perch and new rotors and new wheels. Unless they've released new 5x100 kit with stronger hubs that im not aware of. I just finished this conversion yesterday. |
| | #22 | |
IWSTI Addict since: Jan 2006 Trader Rating: (1) | Quote:
| | #23 | |
IWSTI Addict since: Aug 2003 Trader Rating: (0) | Quote:
i just did the swap.......ah well.....more 17x9 options | |
| | #24 | |
And there's no rear super bearing upgrade for the 5x100 STIs yet (let alone one for my WRX ) This ad is not endorsed by this member. Please register or login to hide this ad. | |
