Old 04-08-2004, 09:33 AM   #1
IWSTI Addict since: Sep 2003
Send a message via AIM to chrisfx811
i have recently installed the following suspension mods:
sti pinks
hardened strut mounts
perring rear sway bar and hd mounts
now when driving my rear suspension makes a clunking noise when i go over bumps or rough road surfaces.
i have virtually no wheel gap in the rear with the springs. could this be too low?
i have double checked all the bolts on the sway bar set-up and everything seems to be tight, so i am not sure if this is the prob either.
i still have the stock endlinks for now.
can someone please offer some insight... it is much appreciated.
thanks chris
chrisfx811 is offline   Reply With Quote
Old 04-08-2004, 10:06 AM   #2
IWSTI Addict since: Dec 2003
make sure your swaybar didn't "flip" over on you when installing it and that it's not hitting or binding down there. there's a thread on nasioc about it (STiLLWILL). another issue could be that the top hats weren't oriented correctly on the strut and the springs are clunking around....
DMikko is offline   Reply With Quote
Old 04-08-2004, 10:08 AM   #3
Car: SR40'd '04 STi
IWSTI Addict since: Nov 2002
Chris - I have the same suspension set-up as you, aside from the swaybars. I have heard a "clunk" coming from the driver's side front end while cornering and going over bumpy, "washboard" type surfaces. It sounds as though it's emanating from the steering column somewhere. I have done extensive asking at several forums, and BELIEVE the noise I'm describing is a common attribute/complaint amongst Impreza owners going back a few years. Here's a thread from NASIOC that may prove helpful, and is the one I'm referring to. HTH.
http://forums.nasioc.com/forums/show...noise+steering
mindchatter is offline   Reply With Quote
Old 04-08-2004, 11:43 AM   #4
Default Victoracers
maybe it's the center diff complaining (thunking) about the loss of traction on the "hopping wheel"
it happens to me and i wrote my thoughts about this in the forumn you linked to above.
with larger swaybars installed they could exasperate the issue
Old 04-11-2004, 07:03 PM   #5
allright, picked up jack and stands @ sears. GOOD PRICES TOO!
basically re-installed the rear sway bar: regreased, set on stiffest setting, retightened after i dropped it.
the noises seem to be all but gone for the most part.
i still get some type of clunking sound when i go over speed bumps or dips. not nearly like before. is this normal for any of you guys with the same mods?
also... my rear end seems to have finally settled and is quite low. i noticed when dropping the car from the stands that the pinks compress about 3 full coils when the car is down. is this how low they should be?
fwiw, i have a sub and amp in my trunk, prolly 50lbs tops.
Old 04-11-2004, 08:55 PM   #6
IWSTI Addict since: Apr 2004
Check the tightness of the nut on the strut if the klunk occurs mainly during slow speeds, pulling in and out of driveways, or coming to a stop at a light or stop sign.
stiparts@adelphia.net is offline   Reply With Quote
Old 04-11-2004, 09:27 PM   #7
^^^ sorry to ask stupid question, but how do i access the strut tops in the rear?
from wheel well?
Old 04-11-2004, 09:29 PM   #8
you have to take the back seat out
Old 04-11-2004, 09:31 PM   #9
Default APS BOV
oh, and don't over-tighten the strut top nuts. they snap pretty easily. find the correct torque spec.
Old 04-11-2004, 09:58 PM   #10
thx
Old 04-12-2004, 07:24 AM   #11
Car: SR40'd '04 STi
14.5ft/lbs on the strut tops. (no more, cause yeah, they will snap off)
Chris - I have a sub enclosure and two amps in my trunk, probably in the 50lb neighborhood.....my pinks in back are low enough to where there's no discernible wheel gap. Myles' ride has the same springs, but w/o the heavy audio set-up, and his car sits 1/2-3/4" higher in the rear than mine. HTH.
Stu
Old 04-12-2004, 08:01 AM   #12
IWSTI Addict since: Jul 2003
Do you mean the nut on top of the strut (tube) that bolts it to the strut mount ? Or do you mean the strut mount/body nuts or strut/lower knuckle nuts ?
My noise seems to be occuring in exactly the same situation that you described in your post.
-Sporty
SportyBry is offline   Reply With Quote
Old 04-12-2004, 09:30 PM   #13
OLD GUY VENDOR
Car: karting, sports car
Fav Mod: racing instructor, service manager
IWSTI Addict since: Jan 2004
Stu
Stu ,..are saying my car is "jacked up" ???? lol ,..thanks alot,.... ops:
944turboguy is offline   Reply With Quote
Old 04-14-2004, 06:44 AM   #14
14.5ft/lbs on the strut tops. (no more, cause yeah, they will snap off) -Stu
Crap! I bet that's what happened with mine. It was a real chore tightening down my rear strut bar, and I'll bet my over-zealous tightening broke a stud.
Anyone know what size I'll need to pick up to replace it ?
-Sporty
Old 04-17-2004, 10:08 AM   #15
well, i re-installed the sway bar, end-links, and re-greased the bushings as mentioned. but now, the clunking is back.
i shecked the strut tops and they are all pretty snug.
all i can think of now is to have the struts checked out at the dealer and wait for them to tell me somethings wrong because of the mods i did!
this is very frustrating.
add to this, my horrible mpg ever since i did a snorkus removal mod.
went from 250-275 per tank down to 150-180 per tank!
dang it.... it's a toyota prius next for me!
