Old 05-02-2004, 08:22 PM   #31
IWSTI Addict since: Sep 2003
Send a message via AIM to chrisfx811
Default Aftermarket top mount intercooler
well, i went to the dealer to have them take a look at my rear struts.
i don't believe they looked at them, because they said the noise is coming from my perrin sb hitting the exhaust. there is approx 1" of gap when the car is still and when it moves around, the bar rotates and clunks against the muffler.
the svc tech said the bar had some wear on the paint, and the muffler looked like it had similair markings.
i went to lowe's to but a piece of pipe insulation and wrapped it on the bar. now when i repeat the same driving conditions, i get the noise but not as harsh.
so i'm led to believe that the bar is the cause of the prob.
my question now is: will purchasing perrin's sti spec endlinks help with this situation? i.e., are they the correct length to offset the longer hd sway bar mounts?
or will i be better off just going with the poltec endlinks which are adjustable?
chrisfx811 is offline   Reply With Quote
Old 05-02-2004, 08:25 PM   #32
IWSTI Addict since: Jun 2003
Default WTB: factory air intake
The noise is most likely not the RSB hitting the exhaust, but the RSB ends hitting the end-link brackets on the trailing links.
FT@SGP is offline   Reply With Quote
Old 05-02-2004, 08:52 PM   #33
what would you suggest i do next?
upgrade endlinks?
ditch this brand of swaybar?
donate car to charity and buy a vespa? j/k
Old 05-02-2004, 09:05 PM   #34
LOL, hmmm... a Vespa
I really don't have answer for this at this time frankly. This is the issue that is related to that famous "flipping" problem. We are working with Cusco, Poltec, Z1 Performance, etc. to find a resolution. I think what we will be doing, not to directly resolve this issue, but to slightly change the chassis balance on our car, is actually take the rear bar out and put 50 to 100 lbs/in. more springs on the rear. But that is not definite at this time.
You should be glad that you are getting the clunks, they mean that your bar will not flip as long as the clunks are there
Old 05-02-2004, 09:09 PM   #35
so as far as rsb's are concerned we have various probs:
perrin: hd mounts are too long
cusco: has issues with the bar "walking" to one side or another
how are the hotchkis setups? i see they come with everything from mounts to bushings to endlinks?
Old 05-02-2004, 09:18 PM   #36
Believe me the issue is not a Cusco issue. The issue is installation and end-link mounting bracket design that is located upwards on the trailing links. This will not be an easy solution.
However, I believe - but cannot substantiate at this time - that Cobb and Hotchkis bars will either not exhibit this or very little of it. But testing is just too extensive for us to perform with all different configurations of springs, coilovers, etc.
We just need some patience and see if there is a cost-effective solution. We are working on it...
Old 05-02-2004, 09:22 PM   #37
i saw in a post on nasioc, that poltec had made a hd mounting bracket that the endlinks attach to.
i wonder if this is what's needed?
http://forums.nasioc.com/forums/show...5&pagenumber=4
Old 05-02-2004, 09:29 PM   #38
Default Weird Noise at Idle
Read the latest posts in that thread, I do not think those address the real problem but just the sympthoms.
Old 05-03-2004, 05:51 AM   #39
Car: Aspen White 04 STi
IWSTI Addict since: May 2003
Send a message via ICQ to choonzAWR Send a message via AIM to choonzAWR
Default HVAC bulbs not working now...
whoa 150ish? I have the HKS bov and snorkus removal and its still doing above 260mpg... of course i always try to shift around 3 or 4k =]
choonzAWR is offline   Reply With Quote
