| Gold Member
Car: STi STi STi STi STi Fav Mod: My BLUE rotas! =p Location: Goodyear, AZ Posts: 237
IWSTI Addict since: Mar 2007 Trader Rating: (1) | How would I go about ajusting my wheels... I put my Coilovers on last night and all of them are fine except my rear driver side...It is angled inward... ![]() Is this bad...OR is it just going to make it worn on the inside of the tire? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Gold Member
IWSTI Addict since: Mar 2007 Trader Rating: (1) | I will prolly take it to an alignment place...then..I Will search though as well...maybe it is somethinf I can do myself... |
| | #4 | |
| The Next Petter Solberg | Quote:
Yes it is bad. By angled, I assume you mean you have massively negative camber. It is worse if the inside of your tire is rubbing the strut body. You will also create more camber wear on your tires if you leave it like that. | |
| | #5 | |
| Gold Member
IWSTI Addict since: Mar 2007 Trader Rating: (1) | Quote:
There is NO rubbing...it is just inward like here is looking at it from the back of the car... =/====|= It is noticeable amount of camber...but not TOO crazy. There is no camber rates for the back...only the fronts...but I Am going to my local Shop and they will be putting a camber kit on it for like $25. And do the alignment adjusting and all that good stuff. | |
| | #6 |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,344
IWSTI Addict since: Apr 2005 Trader Rating: (10) | You NEED to get an alignment after installing coilovers (or springs). Otherwise, the coilovers are simply being wasted. - Andrew |
| | #7 |
| Gold Member
IWSTI Addict since: Mar 2007 Trader Rating: (1) | I knew I was getting one either Friday or sat...but since it is bad at what it is set to know...I already have an appointment for a check up and alignment for 2:30... |
| | #8 | |
IWSTI Addict since: Apr 2005 Trader Rating: (10) | Quote:
![]() - Andrew | |
| | #9 |
| Platinum Member Car: '05 CGM STi Fav Mod: What's RCE made lately? Location: Beaverton, Or Posts: 1,506
IWSTI Addict since: Nov 2004 Trader Rating: (0) | I wouldn't let the shop put a "camber kit" on your car. It's probably just camber bolts which you don't want with your setup. |
| | #10 | |
| Gold Member
What will it do? | |
| | #11 | |
| Moderator | Quote:
| | #12 | |
| Gold Member
I Still have yet to finish my suspension setup...My STI only has 400 miles on it still...Even has Papaer plates...haha | |
| | #13 | |
| Moderator | Quote:
| | #14 | |
| Gold Member
![]() Thanks for your input though... This ad is not endorsed by this member. Please register or login to hide this ad. | |
