Old 04-03-2007, 01:09 PM   #16
OT stealth mod
Car: 06 obp sti
Fav Mod: Vodka injection.
IWSTI Addict since: Aug 2004
Send a message via AIM to dailydriversti
Originally Posted by gtsxr
I used Group N rear strut tops and they fit well. The PSS9's are designed to work with the stock top hats, so stock or Group N in the rear will work with no problems.
-Pete
Thats interesting.
We tried installing a set a couple weekends ago, and the Group N rear hat wouldn't sit down all the way on the spring.
dailydriversti is offline   Reply With Quote
Old 04-03-2007, 01:20 PM   #17
Car: 06 CGM STi
IWSTI Addict since: Jan 2006
Originally Posted by dailydriversti
Thats interesting.
I'm assuming you used the supplied upper spring perch and rubber gasket that came with the kit. If you look at the second pic in Thrlskr's thread, the two coilovers on the right are for the rear. The upper perch supplied, along with the rubber peice on top of it, fit snugly into the metal cylinder that is on the bottom of the Group N and stock tophat. I might be able to get a picture of it tomorrow if you are having trouble visualizing how it fits together. The directions supplied by Bilstein did a decent job of showing how everything fit together.
-Pete
gtsxr is offline   Reply With Quote
Old 04-03-2007, 01:21 PM   #18
OT stealth mod
Car: 06 obp sti
-Pete
Oh crap, you are right, i get it now.
Uh....who reads instructions
Old 04-03-2007, 06:46 PM   #19
Car: Black 06 STi
Fav Mod: PSS9
IWSTI Addict since: Dec 2006
gtsxr:
You mention spring rates for different suspension systems. What range would you consider the ideal spring rate for the PSS9 system for someone like you who intends on using the car as primarily a daily driver with occasional autocrosses and few track days? Would you consider additional GC coilover springs at different rates?
I was initially thinking that 440/380 lb/in could be too much for a daily driver considering the low stock STI rates. My opinion is changing after stretch’s reporting on joust bumpers’ significant effect on spring rate (Thanks stretch!), your review, and others' review of the PSS9.
Thanks.
06STiLtd is offline   Reply With Quote
Old 04-03-2007, 07:20 PM   #20
Car: 06 CGM STi
Originally Posted by 06STiLtd
gtsxr:
Thanks.
The rates I was using with the Ground Controls, 325/300, are about as stiff as you can go on the stock struts. I had cut the bump stops when I installed the GCs, but was still riding the bumpstops as I had the car a little too low I think. The main advantage to going with a coilover instead of just springs is the damper, in my opinion. The Bilstein valving is so much better than the stock vavling that it allows you to run higher rates without really sacrificing ride comfort. A lot of this has to do with not being on the bump stops all the time. Although if you were to lower the Bilsteins, or any coilover for that matter, past their recommended range I'm sure you would start seeing some similar traits.
You could get lower spring rates, but I don't know how that would effect the overall travel of the damper. My thinking is the system has a specific amount of bump travel that is designed for a specific spring rate. If you were to put a softer spring rate on the damper, you would get more jounce travel when hitting a road imperfection since there would be less force from the spring to counter act the force of the wheel moving upwards. This means that the static ride height of the car would have to be higher to compensate for the lower spring rate. I don't know if that makes any sense as I've been at work for 14 hours now and I might not be thinking straight.
-Pete
Old 04-04-2007, 05:39 AM   #21
wdb
dances with roads
IWSTI Addict since: Apr 2005
I should probably do a little more research before asking, but are they height adjustable, and if so is it possible to retain stock or near-stock ride height?
Old 04-04-2007, 05:45 AM   #22
Car: '04.5 STi
IWSTI Addict since: Apr 2006
Well, they're coilovers... so they're definitely height adjustable. You should be able to get close to stock ride height. If you can't all you have to do is swap in longer springs.
Old 04-04-2007, 06:04 AM   #23
Originally Posted by mofoSTI
I may have found a new set for 1600$ new.
suscribed
May I ask where you found these for $1600?
tnt_3 is offline   Reply With Quote
Old 04-04-2007, 06:29 AM   #24
Car: 06 CGM STi
eshocks.com has them for $1599.00 with free shipping.
-Pete
Old 04-04-2007, 08:03 AM   #25
Car: 200? WRX STI
Fav Mod: Super EX/RM-01A
IWSTI Addict since: Nov 2005
Send a message via AIM to o2sys
more reviews please looking to buy these sooN!!!
o2sys is offline   Reply With Quote
Old 04-04-2007, 09:25 AM   #26
Car: 05 Subaru WRX STi
IWSTI Addict since: May 2006
These are looking better and better to me with every review! I really like that you can use the Group-N tops in the rear without modifying them. Great price too!
mtskibum16 is offline   Reply With Quote
Old 04-04-2007, 06:25 PM   #27
Car: 07 Impreza WRX STI,
Fav Mod: Track days!!!
IWSTI Addict since: Mar 2007
Send a message via AIM to GoodTimes
Great Review man, do you have any pics of the car lowerd?
GoodTimes is offline   Reply With Quote
Old 04-04-2007, 06:37 PM   #28
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
IWSTI Addict since: Sep 2004
Eshocks.com and one of my vendor buddys richard at racerfx. I dont think he has a web site, but he hores out great products for jobber prices ( cost + 10% )
Old 04-05-2007, 11:58 AM   #29
Car: 06 Subaru WRX STi As
Fav Mod: Bilsteins PSS9
IWSTI Addict since: Sep 2005
wow... can you hook us up with your buddy for great prices?
SubySTI06 is offline   Reply With Quote
Old 04-05-2007, 12:27 PM   #30
Car: 05 WRX STi
Fav Mod: Seat Time
IWSTI Addict since: Mar 2005
I'm glad you are enjoying yours too!
