Old 03-22-2007, 05:18 PM   #16
Car: 05 Subaru WRX STi
Fav Mod: Cusco Zero-2R
IWSTI Addict since: Feb 2005
I've seen a video where Spoon Sports did this for their race cars with excellent results. I don't remember, but it was either a Honda Fit, Civic Type-R, or S2000. Definitely interesting if nothing else.
froggy is offline   Reply With Quote
Old 03-22-2007, 05:28 PM   #17
GT R US
IWSTI Addict since: Dec 2003
there are no shortcuts. i swear i could sell some of you guys those x-ray glasses in the back of mad magazine.
here's my recipe for a chassis so stiff you'll swear off the viagra:
gt spec subframe brace set
gt spec ladder brace
gt spec fender braces
an 8 point or better yet, 12 point custom chromoly roll cage. weld it in, don't bolt it in. if youre willing to add 30 lbs for the stiffening it offers, do your cage like we did. we bypassed the floor completely and welded two 2"x2" tubular steel rails along the rocker panels. the upper chromoly cage is welded directly to them. search "nhra rules" for the layout or pm me. the next round will finish the cage with a top hope. it's going to be a pia to move the fuse box on the left side to accomodate the front support.
you can add some seam welding if you want but i'm not sure its necessary. whatever you do, don't count on that stuff.
Old 03-22-2007, 07:00 PM   #18
Fav Mod: JDM STi Performance Muffler
IWSTI Addict since: Mar 2004
Slightly offtopic....
I plan on using that stuff to "stiffen" my V-Limited.
300hp@6000rpm is offline   Reply With Quote
Old 03-23-2007, 09:16 AM   #19
Car: 05 WRX STi
Fav Mod: Seat Time
IWSTI Addict since: Mar 2005
Originally Posted by CGMDan
In regards to the foam, Back when I was involved on Miata.net people over there starte using it on the bottom frame rails with success. But that was back in the mid to late 90's.
So who knows.
Yup we miata.net-ers were using belco foam in 8lb variety. Worked very well!!
Old 03-23-2007, 04:15 PM   #20
IWSTI Addict since: May 2006
That should work well. We use a similar product in the back of some of the body kit work we do at my dad's body shop. It helps crappy fiberglass kits that people buy from cracking so bad.
mtskibum16 is offline   Reply With Quote
Old 03-24-2007, 12:40 AM   #21
Banned
Fav Mod: knowledge
IWSTI Addict since: Apr 2003
Send a message via AIM to Guest_1u53r
I applied it to the hollow member on my 02WRX that goes along the top of the trunk between the strut towers. It made it sound deader but did nothing otherwise.
You have to be VERY careful how much of this you apply, as it's not without weight and it definitely has the ability to balloon body panels if you use too much. 300Z guys used to use this stuff to debateable results.
Guest_1u53r is offline   Reply With Quote
