Old 03-08-2007, 06:49 AM   #1
IWSTI Addict since: Dec 2003
Default Rear Toe In of 0.72 degrees!--Update after new spindle and alignment!
After a recent fender-bender (right rear wheel vs. curb--wheel lost), which required replacing the rear passenger side lateral links, the wheel bearings, and of course the wheel itself, TWO alignment shops cannot get ride of the significant toe-in! I'm wondering what else could be bent that would cause this to be the case. I've crawled around under there, loosened and retightened all the lateral link bolts; the camber-bolt is turned fully inward... Could the part of the hub assembly to which the lateral links attatch be bent?
I could go ahead and purchase some adjustable lateral links (Whiteline, part number KTA107) and camber bolts, but if I should go back to the repair shop for further diagnosis and repair, then insurance would pick up the added cost, not me.
Experience and thoughts are welcomed--Thanks!--Tim
timb is offline   Reply With Quote
Old 03-08-2007, 06:56 AM   #2
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
no help here, but i would definitely let the shop try and work it out first. you have insurance for a reason.
i wouldn't use a band-aid (adj. lateral links) to fix the problem.
Old 03-08-2007, 07:09 AM   #3
Wheel33tist Whore
IWSTI Addict since: Dec 2004
when i lost a battle to a curb my hub was actually tweaked along with the strut (in my WRX).
Old 03-08-2007, 11:32 AM   #4
Car: 07 STI BABY!!!
Fav Mod: Driving School
IWSTI Addict since: Oct 2006
Trader Rating: (14)
Send a message via AIM to Pearson II
I say you should let a shop try and figure it out. What is your RR camber reading right now? If your camber is way out then the factory cam bolts won't be able to adjust the toe back into specs. Def do not get any after market parts to fix this problem. There is something wrong that needs to be addressed before you change anythig else back there.
Pearson II is online now   Reply With Quote
Old 03-09-2007, 06:01 AM   #5
Default Thanks Guys....
...I've got an appointment at the shop Monday morning.--Tim
Old 03-27-2007, 09:22 AM   #6
Default Update after new spindle:
New spindle was installed, here are the NEW alignment specs:
FL: Caster 5.0, Camber -1.1, Toe 0.00
FR: Caster 5.0, Camber -1.0, Toe -0.05
RL: Camber -1.5, Toe 0.00
RR: Camber -1.5, Toe 0.10
Not perfect, but definitely better.
Question though for those in the know: On our cars what is the conversion for degrees to millimeters? i.e., toe out of -0.05 degrees equals how many milimeters toe out?
Tim
Old 03-27-2007, 05:09 PM   #7
Car: 07 STI BABY!!!
Trader Rating: (14)
As long as my math was correct it is 0.02mm.
