Old 03-07-2007, 01:44 PM   #16
IWSTI Addict since: Jan 2007
So I still would like a little more input for some alignment numbers.
I am going to go with the RCE springs with the Group N top hats and the whiteline camber bolts.
More feed back is greatly appreciated.
offroadracer99 is offline   Reply With Quote
Old 03-07-2007, 02:07 PM   #17
Car: '05 CGM STi
IWSTI Addict since: Nov 2004
Max out your front neg camber. Whatever that may be. Using camber bolts you WON"T have too much. Assuming you are not using camber bolt in the rear, have as much positive camber in the back as the slop in the system allows.
It's had to give you exact numbers since you may or may not have the adjustability to achieve those numbers.
But if you must have them try
-1.5 to 2.0 in the front
-1.5 rear.
0 toe.
Also remember that whatever spec someone gives you, works for them. It's up to you, your driving ability and how your using the car, to determine if those specs work for you.
