Old 03-03-2007, 09:06 AM   #16
Car: Silver 05 WRX STi
IWSTI Addict since: Dec 2004
Send a message via Yahoo to import111
Every set of coilovers I have ever owned has made noise. It is a part of having a modified car. Play music louder, hehe.
import111 is offline   Reply With Quote
Old 03-03-2007, 03:57 PM   #17
Fav Mod: Steering Rack Bushings, Rubber, and Camber Plates
IWSTI Addict since: Jun 2005
Send a message via AIM to S1MPSONS
Originally Posted by neverendingmods
Smear a good finger glob of Marine grease(blue/non water soluable grease) on the pillow balls f/r. Drive around 50 miles and look at how the grease is pushed out of the eye.Then, resmear around. You're hearing the metal on metal clank of dry pillow ball/balls. No big deal as 1st smearing of grease is good for numerous resmears. Make sure to frequently strip/regrease in roadsalt conditions. I used these coilovers(Zero 2R's) on my old REX for 30K miles. I am getting these for the 06STi . When kept dry, the pillowballs will actually wear out rapidly allowing the eye loop to widen on the ID and the ball to misshape.
This is common on any Pillow ball top coilovers which are WELL worth it over non pillow ball tops.
Take care of your Balls!
I've never handled coilovers before. What exactly are you referring to when you say "the eye"?
Also, has anyone successfully run these for track or autox? I know its mostly the driver but has anybody placed high up in a competetive class running Zero2R's?
S1MPSONS is offline   Reply With Quote
Old 03-03-2007, 07:59 PM   #18
Car: 08 Z06 Corvette
Fav Mod: Jack Jack
IWSTI Addict since: Oct 2005
quite coilovers != coilovers with pillow-balls
I'll try the grease idea... on really wet days my rears quiet down alot. Maybe that was the issue. These are $$$$$ Ohlins, so Im a little disappointed by the noise. THen again, the performance has been so shockingly good and versatile, I dont want to mess with success.
RainMaker is offline   Reply With Quote
Old 03-03-2007, 09:10 PM   #19
Car: 06 STi + 96 Miata
IWSTI Addict since: Aug 2005
I won the 2006 STU Pro Solo National Championship running Cusco Zero 2R's. They were set 5 up front, 4 in the rear.
blkwrxwag is offline   Reply With Quote
Old 03-03-2007, 09:11 PM   #20
To the OP - check your top nuts are tight enough. Sometimes they work loose and that will cause some clunking as it introduces play into the top mount.
Old 03-03-2007, 10:16 PM   #21
WOW! Congrats!
What spring rates are you running with these? Do you ever drive on the street? How does it feel?
Any down sides to these coilovers you can to discuss? I assume you are satisfied with your decision to run Zero 2R's considering you won the National Championships, but just in case you have any regrets I would like to know.
Old 03-03-2007, 11:21 PM   #22
WOW! Congrats!
They were 10K/8K.
No downsides other than they are single adjustable and not rebuildable in the US.. The car is not a daily driver, but they were very comfortable on the street.
I say "were", since I recently switched to Zzyzx coilovers. They have the Koni DA 8611 shock which is tough to beat for AX.
Old 03-03-2007, 11:34 PM   #23
Car: '06 STI
Fav Mod: air freshener!!!
IWSTI Addict since: Jan 2006
Good job blkwrx!
I am the only DOT tired car to get under 1 minute at Horsethief mile (including vettes, vipers, lotus, M3, EVOs, all of the "Touge" shootout cars, etc)
I believe that the Zero 2r's are the best shocks in the sub-$4k price range (actually about $2k). I dont think its fair to compare them with high end $10k-plus CO's. I believe that $2k on Zero 2r's and the remaing $8k on other important items will get you a much better car than $10k on CO's alone. BTW, I have a total of about $3k in my suspension and I will have about another $1k when I'm done.
As for the noise, I got none from the CO's. I do get random noise that I believe are from the rear diff.
Does the noise happen when the shock changes direction or only when getting heavily loaded? We need more info and of course, check all fastners etc.
Old 03-04-2007, 02:57 AM   #24
Car: AW 05 WRX STi
Fav Mod: Recaro Racing Seats
IWSTI Addict since: Sep 2004
Send a message via AIM to JKonquer Send a message via MSN to JKonquer
i notice that mine spring is skipping when wheels are turned. is that mean because the pillowball needs grease?
JKonquer is online now   Reply With Quote
Old 03-04-2007, 03:45 AM   #25
Car: 05 Impreza | STi
the downsides of the zero 2r
-adjustable knob on the bottom, not very convient
-bit stiff for daily driving..for that regards, set mine at 1 Fr, 1 Rr
other then that, it's perfect
STi8 is offline   Reply With Quote
Old 03-04-2007, 01:24 PM   #26
Car: AW 05 WRX STi
i feel that at 1 setting. the car feels too bouncy.
i think 2 or 3 is perfect. it matches the spring rate much better
Old 03-04-2007, 02:42 PM   #27
Car: '06 STI
You're prob right about the settings.
I let my 6'5" buddy drive my car to LA, he hit a big bump on the 405 and actually banged his head really hard on the cieling Hes 2 goodto wear a belt and the stock seats are very springy) I use #5 at the track. #2 or #3 is prob a better compromise.
Old 03-04-2007, 03:02 PM   #28
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
IWSTI Addict since: Jun 2004
Trader Rating: (14)
I would tend to disagree with that, but I don't want to start an argument
Old 03-04-2007, 05:29 PM   #29
Car: 06 STI
IWSTI Addict since: Apr 2006
Send a message via AIM to tinamina
The noise only happens when I am driving slow, regardless of if im going straight or turning.
tinamina is offline   Reply With Quote
Old 03-04-2007, 05:57 PM   #30
Car: AW 05 WRX STi
what a good wy to tighten the perch, so it won't get loose?
