Old 03-01-2007, 10:33 AM   #16
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
Originally Posted by stretch
Yes, they're different, but that longer stop is used in the rear. That's why I think the rears ride on or near the bump stops despite having more travel. I'd install the same Energy 9.6111 bump stops front and rear.
I'm actually currently running without bump stops in the rear (didn't plan ahead when installing Konis), which makes me nervous, but there's so much travel back there that I haven't felt the car bottom out even where my wife's Camry clearly does.
If you tow things or find yourself routinely with four passengers and a full trunk, then- and only then- would you want to keep a longer bump stop- just to keep the rear from sagging from the weight. In that case, I'd recommend installing your uncut front bump stops in the rear (or just cut one progression from the rear).
Sounds like its probably a done deal. I think Im gonna try to do this next weekend but it will depend on the weather. Ive got snow again and my car wont fit all the way into the garage. I did my TiC super shift kit when it was sub 20* out w/ the garage door open. Im not in a hurry to do that again.
Old 03-01-2007, 10:50 AM   #17
IWSTI Addict since: Mar 2006
Originally Posted by CGMDan
Stretch- not to hijack, but have you measured the spring rate of the bump stops? How much stiffer are they than the springs?
Here's a graph:
http://www.iwsti.com/forums/attachme...6&d=1163518303
They start at around 300lb/in, more than the springs themselves! Your total spring rate once on the bump stops goes from ~215lb/in to ~515lb/in.
It's all in this thread: http://www.iwsti.com/forums/showthre...919#post968919
Old 03-05-2007, 08:41 AM   #18
Moderator
Fav Mod: Majin
Bought a strut spring compressor set on Saturday and just ordered the bumpstops. Updates to come...
Old 03-05-2007, 03:06 PM   #19
Moderator
Fav Mod: Majin
Stretch, what do you think about pinks on these shortened bumpstops? Should I replace the springs while I have everything apart? Or should I, in the interest of science, just do the bumpstops and see what difference is made then do springs?
Old 03-05-2007, 03:31 PM   #20
Well, I'd love to see you do things in stages in the interest in science, but if it were me, I'd do it all at once out of laziness.
You'll be shortening your bump stops 1-5/8 inches but lowering the car 1 inch. So, you're only going to have about 5/8" of travel before you hit the bump stops again once you're lowered. That's not much, but at least it's something. I'm not sure what you should expect- your ride quality and handling once lowered will depend upon how firm these aftermarket bump stops are and how far they'll compress. Unfortunately, short bump stops can be very firm.
Old 03-05-2007, 03:47 PM   #21
Moderator
Fav Mod: Majin
Well, I dont necessarily need to spend the money on springs now. As a matter of fact Im pretty sure the ball and chain would frown heavily upon it. Science it is...
Old 03-05-2007, 04:55 PM   #22
Car: 05 Subaru WRX STi
IWSTI Addict since: May 2006
Unless someone comes out with a good stiff spring that doesn't lower the car, I think I am just going to cut the bump stops and get RCE lowering camber plates.
mtskibum16 is offline   Reply With Quote
Old 03-05-2007, 05:04 PM   #23
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
Originally Posted by BoostJunkie
^^True but I disagree on #3. A good alignment costs more than $50, more like $150 from a place that I would trust.
fwiw- i have lifetime alignments from firestone for $150. i have used them twice so far, and they will set in my specs.
but ALWAYS ask if they will use your specs or only set to factory.
Old 03-05-2007, 05:05 PM   #24
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
also- you can get prodrive bumpstops from rallysportdirect.com if you are not comfortable cutting your stops.
Old 03-05-2007, 05:48 PM   #25
Moderator
Fav Mod: Majin
Originally Posted by lackskill
If I have to pull my struts is there any reason I shouldnt use these part # 9.6111?
Got the ones I linked to for <$20 shipped. Ill let everyone know how they work out...
Old 03-05-2007, 06:12 PM   #26
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
sounds good. report back young one.
Old 03-05-2007, 09:23 PM   #27
Moderator
Fav Mod: Majin
asso...
Old 03-06-2007, 08:22 AM   #28
I think I may do this as well. I'll probably do it when I get an ALK since I'll need an alignment anyways. Actually, I might just get RCE lowering camber plates as well....should be a nice DD setup until I get coilovers/ some replacement struts come out that are affordable!
Old 03-06-2007, 08:24 AM   #29
Moderator
Fav Mod: Majin
Cool, stay tuned for updates! I am hoping for an install day this weekend.
Old 03-06-2007, 08:28 AM   #30
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
asso...
