| Silver Member Car: 06 STi Fav Mod: Pro Tune Location: Doylestown, PA Posts: 360
IWSTI Addict since: Dec 2005 Trader Rating: (0) | Ok, yesterday I installed my RCE springs Front hardened strut mount and H&R camber bolts (the bolts were recomended to achieve better handling on this forum.) The rears were a no brainer because the two lower mount bolts on the strut are the same size so I put the camber bolts in the upper position of the two mounting bolts on either side of the car. The front was a different story because from the factory on the front struts there are two mounting bolts as well. The upper of the two has a camber bolt that allows you to adjust camber from the factory, the lower bolt is a standard bolt with no cam for adjustment and is of smaller diameter. I realized that the H&R bolts were too small in diameter to be used on top to replace the factory bolt and would only fit as the lower mounting bolt. I was told by JCS speed that these are the correct bolts. I also tried calling H&R and they couldn't give me a straight answer and directed me to their website. So I used the factory camber bolts for the upper mounting bolt as it was before and used the H&R camber bolts as the lower mounting bolts. Is this setup correct? Should I not have used the H&R bolts? When the camber is adjusted will the upper and lower camber bolts be fighting each other or working together to provide me with more negative camber? Please help me because I want to get the car alighnment done today. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Junior STI Driver Car: 05 STi Fav Mod: the whole dang car! Location: Ithaca, NY Posts: 65
IWSTI Addict since: Jan 2007 Trader Rating: (5) | You have them installed correctly. The bolts both have cams that shift the steering knuckle relative to the lower strut mount, and in doing so, change the camber. The bottom bolt should be set to it's maximum negative camber position and the top (oem) bolt used to fine tune the camber. Last week I did the same thing you're doing now--RCE springs, group n tops, and camber bolts. When I installed the front springs I tried to set the lower bolts to the max setting, but I must have botched it because the alignment mechanic had to readjust them to get enough negative camber. I'm not very good at sussing out that kind of thing so it wasn't too surprising that I got it wrong.......... Be sure to let the alignment mechanic know that you have the aftermarket bolts, and give them the torque specs for the bolts--they get way less torque than the larger diameter oem bolts. I am stoked by the RCE springs. They snug up the suspension but are easy to live with day to day. |
| | #7 | |
| Titanium Member
Car: 05 CGM STi Fav Mod: Bill Location: Neptune Bch, FL Posts: 4,285
IWSTI Addict since: Mar 2005 Trader Rating: (1) | Quote:
OK, crap....I must have installed mine wrong then...I put them in the top hole to replace the stock camber bolts and even though I thought they were too skinny I used a jack to get maximum negative camber and torqued the crap out of them. They've held & work fine..... I wonder if I should go back and do it the way you've done it..... ![]() Here's a pic of the H&R bolt next to stock from my journal.... | |
| | #8 | |
| Titanium Member
| | #10 | |
| Titanium Member
Sorry, hit the wrong quote....fixed it.... Last edited by KarlSTI; 02-27-2007 at 05:51 PM. | |
| | #11 | |
| Titanium Member
| | #12 |
| Spec C Club Car: '08 BMW 135i Location: Centerville, Georgia Posts: 1,666
IWSTI Addict since: May 2005 Trader Rating: (13) | BTW, be careful putting any camber bolts in. This is what Subaru of Gwinnett found the other day while doing my 30k service and an alignment: This was done by an un-named Subaru dealer in Fort Walton Beach, FL. Next time I am down that way I will be bringing this by and talking to their service manager. |
| | #13 |
| Junior STI Driver | Surprise surprise, my H&R camber bolts didn't come with any instructions. Does anyone know the torque specs on these? Also, when using them in the rear struts, I ASSume it goes in the top strut mount hole and that the adjustor side of the bolt faces the back? |
| | #14 | |
| Titanium Member
They go in the top hole. | |
| | #15 | |
| Platinum Member Car: '05 CGM STi Fav Mod: What's RCE made lately? Location: Beaverton, Or Posts: 1,520
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Quote:
![]() Ok it's late and I'm tired. I've been drinking wine and it was the first ting that popped in my head. And no I can't get out of the gutter. I've tried. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| Thread Tools | |
