Old 02-23-2007, 07:49 AM   #1
Fav Mod: Pro-Tune
IWSTI Addict since: Apr 2005
Trader Rating: (17)
Default DS Suspension Under Load=Loud BANG!
Ohlins struts, RCE springs, Cusco camber plates, Progress sways, Kartboy endlinks, GT Spec 3 piece subframe brace set, GT Spec tie brace.
Every time I am turning under heavy load, there is a huge BANG! from the left front suspension. It is REALLY freaking me out. What the hell could it be? Maybe it has something to do with the a-frame bushing mount, I don't know. Anybody else have this?
CB
Interior Flaire is online now   Reply With Quote
Old 02-23-2007, 08:20 AM   #2
Car: 2008 Pinarello FP5
CB
Did you reuse the Subaru OEM conical washer in your install?
Did you just install everything?
- Andrew
Old 02-23-2007, 08:33 AM   #3
Fav Mod: Pro-Tune
Trader Rating: (17)
- Andrew
Yes, I did reuse the conical washer. I also used the spacer washer that came with the Cusco plates. I installed over Christmas. Have not driven the car hard much. Basically, the first time I hammered a corner, it was there.
CB
Old 02-24-2007, 12:40 PM   #4
Car: 2006 - CGM
IWSTI Addict since: Nov 2005
Did you ever figure this one out? If not it might be good to jack it up and take a look around for impact marks, rubbed off paint etc. Pay particual attention to the area on the control arm behind the sway bar, as well as look closely at the pillow ball mount on the camber plate.
Also its not a bad time to re-torque all the associated bolts. After about 1000 miles I found one bolts loose that had had been torqued to factory specs. I didn't use loctite the first time so I could find out which bolt are more susceptible to coming loose. Once a loose bolt was found both the affending bolt and the corresponding bolt from the other side was removed, blue loctite'd and re-torqued.
Lastly a little clarifcation on the symptom might be useful. When turning hard does it make a single loud bump or more than one? Does it do it over large bumps or pothole? Any other times you can repro the sound?
