| | #16 |
| Professional STI Driver Car: '05 Blue/Gold Fav Mod: FPGreen & Track time Location: No. Virginia Posts: 449
IWSTI Addict since: Oct 2004 Trader Rating: (9) | http://www.pegasusautoracing.com/pro...asp?RecId=1206 This link shows the same gauge I use to check camber. Literally takes seconds. If you refer to Nhluhr's string method for toe/thrust in the How-to section, you can learn to do your own alignments. Worth it. Plus save you alot of money if you like to experiment with settings. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #17 | |
| S204 Racer Car: RIP 02 WRX Fav Mod: 2004 Aspen White WRX STi Location: Cincinnati Posts: 3,614
IWSTI Addict since: Dec 2005 Trader Rating: (1) | Quote:
I think I'm keeping them. I need some Pinks, though.and yes, RoyalSTi is a smart man. | |
| | #20 |
| Grassroots STI Racer Car: 05, Subaru Impreza W Location: Cincinnati Posts: 551
IWSTI Addict since: Oct 2005 Trader Rating: (1) | I will be installing these plates very soon and I wonder if it is best to keep the stock camber bolt at "zero" and only use the camber plate to my desired camber or use both?? I'm only going for about -1.25 to -1.50 camber in the front and about -1.0 in the rear. And yes, I'm doing the alignment myself. |
| | #22 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,508
IWSTI Addict since: Dec 2004 Trader Rating: (7) | it's best to set the plates to "equal" locations. then adjust the bolts to full negative (but matching Left to Right). then when you adjust the camber up top, they'll still be matching (assuming you adjust each side equally). then once your camber is where you want it, you adjust the toe to where you want it. |
| | #23 | |
| Gold Member
Car: 06 Subaru WRX STI Fav Mod: Ohlins struts Location: Mckinney, TX Posts: 759
IWSTI Addict since: Oct 2006 Trader Rating: (0) | Quote:
| | #24 |
| Junior STI Driver Car: 06 WRB STI Location: South San Francisco Posts: 56
IWSTI Addict since: Mar 2007 Trader Rating: (0) | So adding negative camber via the plates will increase toe out? I'm getting ready to get camber plates and was hoping that I'd be able to add negative camber at the track and then set it back to my 'street' settings for everyday driving. This doesn't seem that feasible as I won't know how badly I've affected toe. I guess then I need a good compromise for my camber settings. I think I may have found my answer in this thread RCE camber plate questions Last edited by WillisW555; 06-01-2007 at 11:23 AM. |
| | #25 |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,412
IWSTI Addict since: Apr 2005 Trader Rating: (10) | Correct, it's not a good idea to change camber settings between street and track since it will have an effect on toe as well. I have found that -2.5 degrees up front is a good compromise. Some will say it's too much for the street but with 0 toe I have not seen any uneven tire wear and the car drives straight as an arrow. -Dan |
| | #26 |
| IWSTI Club Level 1 Car: The Spaze Mobile Fav Mod: Tuning Location: South O.C., Ca Posts: 13,155
IWSTI Addict since: Jan 2006 Trader Rating: (5) | Slightly off topic sorry--- How much SAI can you guys run without having the top spring retainer contact the camber plate? Last time I got an alignment I told the guy to max out the eccentric camber boolts BEFORE he messed with the camber plate settings(sai). But I dont think he did because I just realized the spring retainer is gitting the camber plate. This is only in the left side: 16.2degrees of SAI and -2.0 degrees of camber. Right side: 15.8degrees od SAI and -2.0degrees of camber. Im pretty sure its that '.4' difference in SAi thats my problem. God damn alignment shops. They dont take their time for anything. |
| | #27 | |
| Grassroots STI Racer Car: 07 sti Fav Mod: whats a mod? Location: milwaukee, wi Posts: 577
IWSTI Addict since: Feb 2007 Trader Rating: (3) | Quote:
| | #28 |
IWSTI Addict since: Jan 2006 Trader Rating: (5) | I'd like my SAI to be even thanks... This ad is not endorsed by this member. Please register or login to hide this ad. |
