Old 02-22-2007, 04:36 PM   #16
Car: '05 Blue/Gold
Fav Mod: FPGreen & Track time
IWSTI Addict since: Oct 2004
http://www.pegasusautoracing.com/pro...asp?RecId=1206
This link shows the same gauge I use to check camber. Literally takes seconds. If you refer to Nhluhr's string method for toe/thrust in the How-to section, you can learn to do your own alignments. Worth it. Plus save you alot of money if you like to experiment with settings.
royalsti is offline   Reply With Quote
Old 02-22-2007, 05:23 PM   #17
Car: RIP 02 WRX
IWSTI Addict since: Dec 2005
Originally Posted by nandanrp
Good to know.
(Rob, sell me your plates! lol)
I think I'm keeping them. I need some Pinks, though.
and yes, RoyalSTi is a smart man.
Old 02-22-2007, 05:40 PM   #18
Car: '05 Blue/Gold
Thank you for those kind words sir
Old 02-22-2007, 05:40 PM   #19
Car: RIP 02 WRX
Old 02-23-2007, 04:54 AM   #20
Car: 05, Subaru Impreza W
IWSTI Addict since: Oct 2005
I will be installing these plates very soon and I wonder if it is best to keep the stock camber bolt at "zero" and only use the camber plate to my desired camber or use both?? I'm only going for about -1.25 to -1.50 camber in the front and about -1.0 in the rear. And yes, I'm doing the alignment myself.
BlueGold is offline   Reply With Quote
Old 02-23-2007, 09:08 AM   #21
Car: '05 CGM STi
IWSTI Addict since: Nov 2004
The camber plates are used for gross camber adjustment, the fine adjustments are done down below.
Old 02-23-2007, 09:31 AM   #22
Wheel33tist Whore
IWSTI Addict since: Dec 2004
it's best to set the plates to "equal" locations.
then adjust the bolts to full negative (but matching Left to Right).
then when you adjust the camber up top, they'll still be matching (assuming you adjust each side equally).
then once your camber is where you want it, you adjust the toe to where you want it.
Old 02-23-2007, 10:31 AM   #23
Fav Mod: Ohlins struts
IWSTI Addict since: Oct 2006
^ Word.
SWortham is offline   Reply With Quote
Old 06-01-2007, 11:10 AM   #24
Car: 06 WRB STI
IWSTI Addict since: Mar 2007
Send a message via Yahoo to WillisW555
Default Re: How do I use RCE Camber plates?
So adding negative camber via the plates will increase toe out? I'm getting ready to get camber plates and was hoping that I'd be able to add negative camber at the track and then set it back to my 'street' settings for everyday driving.
This doesn't seem that feasible as I won't know how badly I've affected toe. I guess then I need a good compromise for my camber settings.
I think I may have found my answer in this thread RCE camber plate questions
WillisW555 is offline   Reply With Quote
Old 06-01-2007, 11:53 AM   #25
Car: 2008 Pinarello FP5
IWSTI Addict since: Apr 2005
Correct, it's not a good idea to change camber settings between street and track since it will have an effect on toe as well. I have found that -2.5 degrees up front is a good compromise. Some will say it's too much for the street but with 0 toe I have not seen any uneven tire wear and the car drives straight as an arrow.
-Dan
RaceComp Engineering is online now   Reply With Quote
Old 06-01-2007, 12:05 PM   #26
IWSTI Club Level 1
Car: The Spaze Mobile
Fav Mod: Tuning
IWSTI Addict since: Jan 2006
Slightly off topic sorry---
How much SAI can you guys run without having the top spring retainer contact the camber plate? Last time I got an alignment I told the guy to max out the eccentric camber boolts BEFORE he messed with the camber plate settings(sai). But I dont think he did because I just realized the spring retainer is gitting the camber plate.
This is only in the left side:
16.2degrees of SAI and -2.0 degrees of camber.
Right side: 15.8degrees od SAI and -2.0degrees of camber.
Im pretty sure its that '.4' difference in SAi thats my problem. God damn alignment shops. They dont take their time for anything.
Old 06-01-2007, 09:19 PM   #27
Car: 07 sti
Fav Mod: whats a mod?
IWSTI Addict since: Feb 2007
the .4 difference is probably intentional so it doesnt follow the crown of the road too much. sounds weird, but it helps the car drive straiter.
Old 06-01-2007, 09:27 PM   #28
IWSTI Club Level 1
Fav Mod: Tuning
I'd like my SAI to be even thanks...
