Old 02-21-2007, 09:07 PM   #16
Car: 2007 Limited STI
IWSTI Addict since: Feb 2007
<img src="http://i3.photobucket.com/albums/y93/joshtheazn/crash007.jpg">
heres one more that i just found.
Josh[ua] is offline   Reply With Quote
Old 02-21-2007, 09:11 PM   #17
oh i almost forgot to mention. insurance looked at it today and the guy called me and said that its going to cost around $5,200 to fix everything. hopefully the bodyshop will fix her up soon so that i can drive again. thanks again for all the input and help.
-josh
Old 02-21-2007, 09:28 PM   #18
Car: 06 STi
Fav Mod: boost creep!!!!!
IWSTI Addict since: Dec 2005
damn man, glad u r ok, hope everything will work out. you might wanna replace the front bumber too it is scraped pretty bad,
sti-06 is offline   Reply With Quote
Old 02-21-2007, 09:46 PM   #19
yea hopefully that will be replaced as well as my frontlip that the tow truck driver destoryed...
Old 02-21-2007, 09:47 PM   #20
Fav Mod: me
IWSTI Addict since: Sep 2006
I am so sorry. If your tire was damaged and needs to be replaced, if I remember correctly, look into this.
Point out that in the owners manual it states that tires should have similar tread depth or damage may result in one or some of the differentials. If they are unable to order a new tire shaved, recommend replacing all four. I know you can order shaved at;
http://www.tirerack.com/
Other than that, be sure bolts and nuts in and around area of impact concerning the suspension are all replaced with Genuine Subaru Parts. These bolts are often reused. Ask that all replaced nuts and bolts be saved so that you “know” they have been removed. An impact can compromise the integrity of said load bearing parts and I know how you are going to push the car. It would be the safest thing to do and the insurance company should agree. If not, buy the bolts only from the dealer and replace them anyway. Should not be too much. Ask the repair center to maybe allow you to use their wholesale license for a good price on the bolts if you have to pay. Also, I recommend you re-torque everything after 1000 miles to spec. A cool Subaru tech should be able to guide you. If you need more information on why I think this, PM me.
I had the same thing happen to me when I was on a motorcycle. It ruined my day.
Treadwell is offline   Reply With Quote
Old 02-22-2007, 10:58 AM   #21
Car: 2007 OBP STI with Go
Fav Mod: dealer license plate delete
I would also make sure they check the breaks because that kind of compression can warp a rotor pretty bad
Kylipso is offline   Reply With Quote
Old 02-22-2007, 11:44 AM   #22
Car: 07 WRX STi Limited
Fav Mod: Trunk Monkey
I think I'd replace everything as well, replace what you can with performance parts on both sides. It will be good as new, don't worry.
JiveMasterT is offline   Reply With Quote
Old 02-22-2007, 04:04 PM   #23
hopefully ill go to the shop 2morrow and check out on how my cars doing. ill have to remeber to get them to use new bolts and stuff and im pretty sure ill be getting new tires cause they were already pretty gone before the accident. as for the brakes ill see if i can get him to chcek that out to. thanks for all the help guys.
-josh
Old 02-22-2007, 07:07 PM   #24
Car: 07 sti limited
Fav Mod: stealth
IWSTI Addict since: Dec 2006
-josh
Dude how did you run through tires on a new 07 already?????
Sizzle is offline   Reply With Quote
Old 02-22-2007, 07:22 PM   #25
Usually I blow through tires when I'm driving like an asshole.
Old 02-22-2007, 10:06 PM   #26
yea i had like alittle left after 6k miles... so yea you could say that i drive like an asshole haha
Old 02-22-2007, 10:08 PM   #27
6k miles holy **** dude. I don't drive like a granny but I sure as hell have most of the life of my tires left after 4500 miles. Wow.
Old 02-22-2007, 10:32 PM   #28
IWSTI Addict since: May 2005
Send a message via AIM to eze13sti
check the brakes. i had something similar but to the front end. 2k in dmgz. car drives like new tho
eze13sti is offline   Reply With Quote
Old 02-23-2007, 09:38 AM   #29
Wheel33tist Whore
IWSTI Addict since: Dec 2004
Replace as much as possible.
take it to a chasis expert, it'd suck to put all the work into it to find out it'll never drive the same b/c the chassis is twisted.
Old 02-23-2007, 10:07 AM   #30
thanks again for all the input. heres an update of the situation. i just recieved a $4786.81 check yesterday with a paper attached listed with everything that needs to be replaced. theres like 25+ parts that need to be replaced and i was reading up on my rims. they said
"Alloy Wheels - $180 - remanufactured"
i called subaru up and my limited rims cost about $360 a piece and i was wondering if u guys knew what they ment by remanufactured.
there are also alot of parts that just have part numbers next to them and some say order from dealer. do u guys know if they replace all my parts with genuine subaru parts?
they also forgot to write up $500 for my front lip..
but anyways ill probably stop by at the shop today to check out whats going on and ill keep you guys updated
and yet again, thanks for all the help.
-josh
