Old 02-14-2007, 06:55 PM   #1
Car: 06 OBP STi
IWSTI Addict since: Sep 2005
Default What's your take on this install guys?
Hey guys, have done a search, but haven't really come to a conclusion regarding the install about the Whiteline ALK. I spoke with my Uncle who suggested I get the ALK put in at West End before my Alignment. He said the install was a PIA to do. Is this true? Or is this install fairly straight forward. I have looked online regarding the install process and it looks pretty straight forward, although I do have an 06 and have read a few guys commenting on clearance issues. ??? 06 guys chime in here please. What's your guys' take on this in comparison to instally a Whiteline 27-29mm FSB (which I have done myself)...??? Thanks!
Ryan
r12rex is offline   Reply With Quote
Old 02-14-2007, 07:27 PM   #2
Car: 2006 - CGM
IWSTI Addict since: Nov 2005
Before I did mine, I saw a few comments like "its not hard, just time consuming". For the most part this is true. It helps to make sure you have ALL required tools before you start. As I recall,the nut at the end of the control arm is 20mm stock and 24mm for the whiteline nut. I had neither of these and ended up making run to Sears. Also I had a 12 point socket for the 184lb bolts and it was twisting too much for my comfort, so I went out and got 6 point 19mm socket. If you have air tools that speeds things up. I didn't and used a socket wrench combined with cordless drill with 3/8 adapter.
The only clearance issues I had are with the rear portion of the subframe brace. With lowering springs, it scrapes on large speed bumps.
The other issue I had was it was difficult to get a lot of torque on this larger bolts. 184lbs for the main bolt that hold the ALK on and 140? I think, for the nut on the end of the control arm. Laying on your back, twisting for all your worth, ugh. A lift would be very helpful. I had better success accessing the bolts from the outside of the car. I couldn't see the bolt, but at least I could get some leverage on it. Also be sure to come back and retorque after 1000 miles.
Old 02-14-2007, 10:31 PM   #3
Sooper Moderator
Fav Mod: Stage 1
IWSTI Addict since: Mar 2006
no installation is hard if you have the right tools and follow the proper procedures but this doesn't always work the way you want it to.
i've heard good things about West End and they supposedly do great alignments as well so why not just use them.
Old 02-15-2007, 08:39 AM   #4
Community Consultant
Car: 2005 OBP STi
Fav Mod: Learning
IWSTI Addict since: Aug 2005
Send a message via AIM to CicioSTi
it was a breeze on my 05
CicioSTi is offline   Reply With Quote
Old 02-15-2007, 11:01 AM   #5
Car: 06 SG STI
IWSTI Addict since: Dec 2005
Just ask Darren what he will charge you. It may be best to have it done at the same time he does your alignment. Either way, get it done before the alignment.
STI Nicholas is offline   Reply With Quote
Old 02-16-2007, 08:25 PM   #6
Car: 05 Legacy
I just (as in JUST) finished installing mine. It is not a hard job. It IS a time consuming job. As someone said, it helps a lot to have all the required tools...all of them. It also helps to take your time and stay organized.
To correct someone, the stock nut is 22mm. The new one is 24mm. You will need to get wrenches in those sizes in order to complete the install.
Just take your time and you should be fine. It isn't hard.
BayRain is offline   Reply With Quote
Old 02-24-2007, 11:31 AM   #7
Car: 2006 STI OBP
Fav Mod: Kartboy SS
IWSTI Addict since: May 2006
Send a message via AIM to Doctor Subie
+1...not hard
Doctor Subie is offline   Reply With Quote
