| | #46 | |
| S204 Racer Car: 05 OBP STi Fav Mod: My Right Foot Location: Rockville, MD Posts: 2,545
IWSTI Addict since: Oct 2004 Trader Rating: (1) | Quote:
| | #47 |
| Super Moderator Car: 08 DGM STI Fav Mod: My wife :) Location: Brooklin, Ontario Posts: 5,685
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Well it seems the dynamic camber question has already been addressed (came here to post.) Nice info Homer and very nicely explained. Something that I don't think was mentioned was that more caster allows you to run less static camber, which in turn can improve straightline braking while still reaping the benefits of negative camber in the turns. Unfortunately, I don't know the proportion of caster to camber ratio (if there even is a general formula/rule or is car specific). |
| | #48 | |
| Junior STI Driver | Quote:
as for a dynamic camber formula. i calculated it roughly the other day (very roughly) and about half a turn of the steering wheel will increase 1 degree of negative camber. (just to give you an idea). | |
| | #49 | |
As for the dynamic formula, obviously amount of castor you have would effect the amount of dynamic camber as you have explained. Thus, it is highly recommened that to get a true static camber reading, you want to have that particular wheel at zero toe. | |
| | #51 | |
As for castor, last time I checked (2month ago), I was at 4.5-4.6*, IIRC. | |
| | #52 |
| Authorized Vendor | We have a local with an 07 going in for an alignment soon. I'll ask him for the caster numbers to get an idea where he is. The 05+ could not get as much camber from just the stock bolts as the 04 could. The reason is because of the spacing between the bolts for the strut to knuckle attachment. The distance between centers on the 05+ was increased. The ALK will increase lift and dive to allow the tire to better follow the road thus improving grip by keeping the tire from "skipping" over the surface. The characteristic comes from the housing, and how it moves the rear of the LCA downward thus changing the forward roll center. The caster portion of the ALK comes from the eccentric bushing installed in it. it pushes the rear of the LCA ourward thus pushing the ball joint attachment point forward. In other words it moves the back our on an arc with the center of the radius being the front bushing on the LCA. because the rear moves out on that arc, and the LCA is rigid the ball joint end moves forward along an arc. remember the centerpoint for the radius is the front bushing on the LCA. What the increased caster will give you is better stability in a straight line, improvement of the dynamic camber curve as you compress the suspension (but not super huge amounts - nhluhr calculated it), and a more quick "natural return to center" when coming out of a turn. Now, given this one would think that this would be the holy grail, and you want as much caster as you can get. Well, it's good to a point. Once you hit that point the handling degrades due to funky stuff going on with weight jacking. The point on the impreza is about 7*. Do not exceed that. I hope this clears up some questions. |
| | #53 | |
| Authorized Vendor | Quote:
You cannot just go out to your garage and slam the camber without affecting toe. Do some reading on Ackerman, and reverse ackerman for some more info. Additionally, do not rule out bumpsteer. On our cars with a stock setup it's not that bad (on the RSX it's pretty sucky). Once you start to drop the car you start changing some angles and the bump steer gets worse. Now, the good springs have a small drop so most (MOST) folks don't really notice it, but if you start to slam the car then you can really notice it. | |
| | #54 | |
![]() Learn something new everyday. Thanks, TiC. | |
| | #55 |
| STI Driver Car: 07 STI BABY!!! Fav Mod: Driving School Location: VA Posts: 239
IWSTI Addict since: Oct 2006 Trader Rating: (14) | TIC...you missunderstood what I wrote. I stated toe has no affect on camber not that camber has no affect on toe. Camber def affects toe. That is why the last thing you adjust when doing an alignment is toe. Could you please explain what bump steer is and how it applies to cars. Thanks |
| | #56 | |
The housing of the ALK is what does the drop to change the lower end of the LCA. There's a really nice FAQ on nasioc, or read the description on our site. I borrowed it from nhluhr (with his permission) as it's the most easy to understand description of what the part does. | |
| | #57 | |
Bump steer is very simply steering by hitting a bump. As one side hits a bump the suspension compresses and changes the toe angle making that side steer. If you do it on the unloaded side then it's not so bad, but if you do it on the loaded side in a turn then it can point the car where you are not telling it to go. Bumpsteer can be corrected with a proper relationship of angles between the LCA and the tie rod. Start changing angles of things so that they are not close, and bumpsteer gets worse. | |
| | #59 |
| Authorized Vendor | hey guys, I had another though on caster on the 07, and clearing this up for sure. Measure the wheelbase. If it's 99.4" then it's the WRX spec. If it's 100.0" then it's the Spec C, and earlier USDM STi spec. |
| | #60 |
IWSTI Addict since: Oct 2006 Trader Rating: (14) | I'll try to do that today. This ad is not endorsed by this member. Please register or login to hide this ad. |
