| | #16 |
| STI Driver Car: 07 STI BABY!!! Fav Mod: Driving School Location: VA Posts: 239
IWSTI Addict since: Oct 2006 Trader Rating: (14) | Any answer? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #17 | |
| Junior STI Driver | Quote:
there are 3 control arms made by subaru for the GD sedans across the world. 1- standard steel control arms (this is what all imprezas RS, WRX, etc get except the sti) 2- standard aluminium control arms: these have the same geometry as the steel ones except they are forged aluminium (this is what the standard jdm sti gets, as well as the 2007 usdm sti) 3- spec-c aluminium control arms: these have different geometry resulting from an extra bend in the chasis mounting point of the control arm. this results in a few degrees of extra castor and an extended wheel base +0.4" (this is what the spec-c jdm sti gets and the 04-06 usdm sti) as a result: 3 >>> 2 > 1 i cannot confirm or back this up, but the aluminium control arms dont have much of a weight advantage over the steel ones (since the steel ones are mostly hollow, whereas the alu ones are solid). so the advantage of #2 over #1 is mostly in better bushings, possibly less flex (not sure) and the bling factor. the #3 is what everyone wants, and are the ones that truely make a difference. its too bad subaru dropped them from the USDM sti in 2007, since there is really no reason to. the cost to them is virtually the same. i believe wikipedia says the reason is the rising cost of aluminium, but that makes no sense since both #2 and #3 have the same amount. | |
| | #18 |
IWSTI Addict since: Oct 2006 Trader Rating: (14) | So, you're basicly saying the 07 STi's have the same suspension geometry as a regualr WRX? I know that most of the 04-06 STi's couldn't get anymore than 1/2 degree of negitive camber out of the from in stock form, but I had no problem getting a full degree. I believe that I can get even more. I plan on finding out next week. SOA may have changed the 07 lca to get a bit more neg camber out of the front to help with the understeer problems people complain of. I didn't have any hint of understeer at VIR this past weekend. |
| | #19 | |
as for the camber difference, that can come from the struts, the ride height difference, or the hub geometry more so than from the control arms. | |
| | #21 |
IWSTI Addict since: Oct 2006 Trader Rating: (14) | also look at the specs that 05 STI WRB posted. it states that a 05 WRX should have 3*35' of caster, not 1* like what i have on my 07. so how could I have the same LCA design as a WRX if the caster specs are different? |
| | #23 | |
but my gut feeling is there is something wrong with that number, it should be about what the wrx has. and finally, yes you are right, moving the ball joint will change the camber. | |
| | #24 |
IWSTI Addict since: Oct 2006 Trader Rating: (14) | I did the alignment myself at the Volvo dealer where I work. I couldn't believe it either when i saw the caster after the swing. I'm taking my STi back to work with me tomorrow to put it back on the rack to see just how much negitive camber I can get out of it. I'll post up some stuff tomorrow. |
| | #27 |
| Professional STI Racer Car: '05 Aspen STi Fav Mod: Wingless Location: Richmond, Va Posts: 762
IWSTI Addict since: Oct 2005 Trader Rating: (4) | Interesting read, I didn't realize there was such a change in suspension geometry of the new Subarus... if it is correct. I thought all Subarus ran approximately 3.0-5.0 degrees of caster. |
| | #28 |
| Junior STI Driver | I have a 2007 and this discussion leads me to wonder why Subaru changed the suspension to reduce castor and camber. I assumed [not sure why] that each new STI would handle a bit better than the one before. Logically, if you are going to make changes in a car like the STI, it should make it handle better, and accelerate better too, as well as get better fuel consumption. If this turns out not to be the case- what were they thinking? |
| | #29 |
IWSTI Addict since: Oct 2006 Trader Rating: (14) | They def reduced the caster by a huge amount, but as for the camber it looks like they increased it. I haven't had a chance to adjust my brother's car at all(a 2006), but from what I've heard I won't be able to get anything near what I got. This also makes me wonder if they changed other things like the spring rates or struts on the 07's. As soon as it warms up I'm gonna try to look at my brother's car more in depth and compare it to mine. |
| | #30 |
| Super Moderator Car: 08 DGM STI Fav Mod: My wife :) Location: Brooklin, Ontario Posts: 5,685
IWSTI Addict since: Oct 2003 Trader Rating: (0) | I just had my 05 STi re-aligned. My right wheel allows me to hit approximately -1.14 deg camber while my left is a ***** and will only go to -.90. The tech dropped them to a relatively even -0.9L and -0.94R. My castor readings, off the top of my head, were 4.58L and 4.68R. Rear camber is -1.48L and -1.52R. Once again, this is an 05. I'm pretty sure I remember reading that the 07s received less castor to reduce the "darty" feeling of the car when steering. This follows with Subaru attempting to make the STi a less demanding car. But 1 deg? wtf. That HAS to be wrong. That is a huge loss of dynamic camber potential, no? This ad is not endorsed by this member. Please register or login to hide this ad. |
