Old 03-07-2007, 10:33 AM   #16
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
IWSTI Addict since: Jun 2005
Trader Rating: (21)
Send a message via AIM to AndrewSS
^ Hrmmm... overall it just made the car a bit more loose (for an event before I got a real alignment it was at about just 0 and it was quite loose then).
I would say mid corner and exit were looser, transitions were looser too.
AndrewSS is offline   Reply With Quote
Old 03-07-2007, 01:01 PM   #17
IWSTI Addict since: Apr 2006
Send a message via AIM to azndc5er
Thank you Homer. That was very helpful. I was under the impression that you could get more negative front camber from 04's than other years. Also, I'll be installing RCE springs, shouldn't that add some negative camber as well?
Lastly, could you elaborate on 'slotting the bottom hole 1-2mm' to gain another degree of neg. camber?
azndc5er is offline   Reply With Quote
Old 03-07-2007, 01:50 PM   #18
IWSTI Addict since: Aug 2006
slotting the bottom hole is just simply slotting it to make it "wider". slot it 1-2 mm towards the outside of the car. this will allow you to pull the bottom of the hub more towards the outside, gaining negative camber.
so you basically increase the slack in the bolt hole by a bit, and when you put it back together, you make sure to pull the hub towards you to seat the bolt against the new slotted side. this doesnt need to be machined, a simple round file can do the job.
homer09 is offline   Reply With Quote
Old 03-17-2007, 04:48 PM   #19
Would slotting be better than just the bolt?
TraSTi is offline   Reply With Quote
Old 03-18-2007, 07:35 AM   #20
i believe so. adjustment is more difficult because you dont have a smooth rotating motion to do it. but if you have a stock camber bolt in the other hole, then you eliminate that problem.
i believe slotting is better because it allows you to retain the beafy stock bolt vs a thin camber bolt. which means you can torque it more and it will be less likely to slip.
