Old 03-12-2004, 01:51 PM   #1
IWSTI Addict since: Nov 2003
Default Re: Warranty?
I don't know which one i should go. I use it for daily drive car, but i go for AutoX at summer time about 5 to 8 times. Can anyone give me some suggestion please. I already have the front and rear strut, front and rear sway bar is coming. so what should l do to next, thanks a lot.
edykh is offline   Reply With Quote
Old 03-12-2004, 02:38 PM   #2
mistkerl
Guest
Posts: n/a
Default Importing STi
If you can afford Coilovers, then I say go for it, no reason to go halfway when you can go all the way.
Old 03-14-2004, 12:41 PM   #3
Car: STi
IWSTI Addict since: Oct 2003
Send a message via ICQ to Transporter_STi Send a message via MSN to Transporter_STi
I have always used springs in every car I had and found it worked for me fine, I don't think you will use the coil system unless you track it all the time.
Transporter_STi is offline   Reply With Quote
Old 03-14-2004, 02:48 PM   #4
Spiteful Old Codger
IWSTI Addict since: Jul 2003
Definitely coilovers, although I would be careful to choose compatible suspension components.
Old 03-14-2004, 08:00 PM   #5
Fav Mod: Stealth mode
Default Go for it!!
My vote is for Eibachs. They are relatively inexpensive and will provide a very noticeable improvement in handling balance without the need to upgrade the struts. Coupled with beefier swaybars, I think you will be very happy with the improvement without sacrificing much in ride quality. The Pinks or Spec-C springs are other worthy options for a bit more money, but having raced on the Eibachs personally, I would not spend the extra money there.
Coilovers will however be clearly noticeable as another step above even that setup, but unless you go with an exceptionally soft spring rate, your butt will feel the difference too. They are great for their versatility and adaptability, but for sometimes autocrossing, probably overkill and more ride harshness than you may be in the market for.
If you are the DIY type and discover that simple springs just aren't doing it for you, you can probably sell them to another STi owner later for nearly as much as you paid, and you are only out your labor time.
It's more difficult to sell an expensive set of 'used' coilovers.
Snax is offline   Reply With Quote
