| | #16 | |
| S204 Racer Car: 04 Fav Mod: teh hot wimmenz Location: so. cal Posts: 4,398
IWSTI Addict since: Dec 2003 Trader Rating: (0) | Quote:
jesus... This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #18 |
| S204 Racer Car: 2006 STI Fav Mod: Recaros Location: Mahan, OR Posts: 2,904
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Since lowering the car seems to be one of the primary contributing factors in causing the swaybar to flip ... it seems reasonable that Subaru would refuse to cover damage resulting from the swaybar flipping when lowering springs have been installed. |
| | #19 |
| Spec C Club Car: AW 05 WRX STi Fav Mod: Recaro Racing Seats Location: CA-burbank and palm sprin Posts: 2,197
IWSTI Addict since: Sep 2004 Trader Rating: (2) | ^^true but i've seen stock suspension sti breaking thier endlinks with spirit driving. subaru should cover the breaking or bending of endinks. and they need to prove that it was caused by springs |
| | #20 | |
| Senior STI Driver Car: 05 Subaru WRX STi Fav Mod: brake ducts.... Location: Chicago Posts: 377
IWSTI Addict since: Jun 2006 Trader Rating: (2) | Quote:
| | #21 | |
| Senior STI Driver Car: 05 STi WRB Fav Mod: Protune Location: western burb, IL Posts: 376
IWSTI Addict since: Oct 2005 Trader Rating: (0) | Quote:
| | #23 | |
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Quote:
1. This thread is about a car that has been lowered. 2. How do weak end links have anything at all to do with flipping the bar? The order of operations is flip, bend -- not the other way around. 3. I do not believe I've ever seen someone break a stock endlink without either flipping the bar, or running a non-stock bar. | |
| | #25 | |
IWSTI Addict since: Sep 2004 Trader Rating: (2) | Quote:
| | #26 | |
because when endlinks turned into c shape, it easier for swaybar to travel around. therefore it make klucking noise when ever lateral bar is traveling up and down and yes you can bent or break endlinks with stock suspension. they are just that weak. compare the front ones and rear. you will know what i mean. i've seen it many times with sipirited driving. | |
| | #27 |
| dances with roads | The stock endlinks did not cause your problem (at least not all by themselves). Neither did your Cobb springs (at least not all by themselves). Your swaybar 'flipped' which is a known occurance even on totally stock STi's. Collect some evidence, make your case, and ping SoA directly if your dealer continues to be a jerk. |
| | #28 |
| Spec C Club Car: Zohsex Fav Mod: 295 rears Location: Ohio Posts: 1,346
IWSTI Addict since: May 2006 Trader Rating: (7) | why are you even bothering with the dealership? go out and buy some kartboy endlinks for $100 and be done with it, there's nothing wrong with the lateral links, they just got scratched |
| | #29 | |
Personally i was testing my waters with the whole warranty thing with Subaru and my local dealerships. Like i figured the whole system is a joke, and i dont play ball well when i have to jump through flaming hoops to get $50.50 worth of damaged parts replaced, when clearly its a defect. Like mentioned before, i'll just be redoing the suspension early, and might as well not stop there and finish up my 35R setup.. TT-u here i come | |
| | #30 | |
| dances with roads | Quote:
| Thread Tools | |
