Old 01-03-2007, 11:11 AM   #16
Car: 06 WRB STI
Fav Mod: Volk Racing RE30 (Diamond Black)
IWSTI Addict since: Oct 2006
Yeah thats what I figured the shop up here is pretty legit.
THye do bang up work.
They probably didnt want to screw up the car without going with the camber bolts or plates.
I dint think I got hosed, but i was just wondering if I needed to push harder to get it to spec.
At the time I had it done I didnt want anything to drastic, so that could also be the reason.
I must have been a little gun shy when i had this stuff done.
TheHammer is offline   Reply With Quote
Old 01-10-2007, 11:44 PM   #17
Car: 06 OBP STi
IWSTI Addict since: Sep 2005
Originally Posted by Darkiller
i don't know why they told you that .. I mean i just went in for my second time and the first time was stock suspension with just a performance aliment and i got -1.2 .. Now with my group N tops in the front and RCE spring and my sways on i got -1.4 . I don't know where you live or where you went .. But i also did go to a place and they kind of told me the same thing you said .. U just need to find a place that will dial it in more because you can .. I am still thinking if i want to get camber plates or bolts to run -2 up front .
some shops arent supposed to put alot of neg camber in since when you hit a rut in the road your call will pull .. so like i said i had to go to 3 shops before the person would put it to as much neg camber as i wanted . He said bring it back with camber plates on and he will dial it in to as much as i wanted .. But also told me get ready to order new tires soon .. LOL ..
Hey was wondering where you got your alignment? Will be getting my RCEs and Strut tops soon and need a legit shop that can do a good job on my camber. How much was the charge? Thanks.
Ryan
PS~I am in SoCal (OC area)
r12rex is offline   Reply With Quote
Old 01-11-2007, 11:00 AM   #18
Car: 2006 - CGM
IWSTI Addict since: Nov 2005
West End Alignment in Gardena
Old 01-11-2007, 11:07 AM   #19
Car: 2006 - CGM
Originally Posted by TheHammer
I was told the negative camber in stock form only went to -85 and change.
This is probably because the mounting holes on the KYBs varies from car to car. Based on many of the reports here, the max camber allowable seems to have gone down between 05 and 06. There are many 06 owners whose alignment guys made a good faith effort to get the max camber and never got close to -1.0. My guy only got -0.4 on one side and -0.7 on the other. If the car would have gone further he would have done it. Note this is without aftermarket camber bolts. I now have plates, and he set them to -1.5.
