Old 01-07-2007, 12:58 AM   #31
Banned
IWSTI Addict since: Jan 2007
edit - found out wat was the problem .. thanks
MR. STi is offline   Reply With Quote
Old 01-08-2007, 08:40 AM   #32
Car: 05 Subaru WRX STi -
Fav Mod: so far, HKS Carbon-Ti catback exhaust
IWSTI Addict since: Sep 2004
Ok, so I went to the dealer to fix my clunk...apparently I had an issue with the strut mount. If you look in the stock strut mount there is a rubber peice within the exterior strut mount rubber housing. The internal rubber peice usually fits plush around a metal bracket...there is a pink painted link to ensure that the interior rubber peice is in the right place....mine was twisted and the interior rubber piece had bulged against the metal bracket...nonetheless, the solution was to remove the defective strut mount and put on a new one under warranty...problem solved!!! until it happens again :-)
kenjib is offline   Reply With Quote
Old 01-10-2007, 09:33 PM   #33
Car: 04 Black/Silver STi
IWSTI Addict since: Feb 2005
Send a message via AIM to Dark_Wing
I assume if out of your warranty Subaru will not replace this...Though I thought I read here before that a few people have had their struts replaced even after their warranty...anyone else ever here of this happening?
Dark_Wing is offline   Reply With Quote
Old 01-28-2007, 02:42 PM   #34
Car: 05 Subaru WRX STI
IWSTI Addict since: Nov 2006
Send a message via AIM to koreano10is
if i were to get a 15k mile checkup sumwhere besides the dealership, does the warrantly still cover the clunking noise? i'm getting that noise too.. i thought it was the water in the intercooler spray moving around but its worse now
koreano10is is offline   Reply With Quote
Old 02-19-2007, 06:13 PM   #35
IWSTI Addict since: Jan 2006
I swear I have this problem on my 07 I just picked up. I have 250 Miles on it and I am hearing a clunk from the rear passenger side when I come to a stop. It sounds like a big 2 liter bottle of soda or something is rolling around in the trunk. I checked the spare to see if it was loose/ I grabbed the car by the tow hook and shook it and I can only duplicate if I come to a stop.
I also have the sound of the rear glass creaking. I thought it might be the glass settling becuase the car is new.
lidrew is offline   Reply With Quote
Old 02-19-2007, 10:23 PM   #36
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
Originally Posted by gills
Actually, the shocks are made by KYB, not subaru, so who should be the ones to blame?
I suffered long enough with that god forsaken clunk that i will never buy a KYB product of any kind again in my lifetime.
my .02
Its not just the strut design, the rear struts are on an odd angle. This coupled with what I am assuming is poor seal design is what leads to clunk and ultimately failure.
Old 02-19-2007, 10:33 PM   #37
Car: 06 Subaru WRX STi
Fav Mod: in-dash dvd
IWSTI Addict since: Dec 2006
Send a message via MSN to scott's06
hey i've had a bit of clunking in the rear passenger side of my 06' but found out it was just my intercooler sprayer bottle...the water froze...not saying its everyones problem but it might shed sum light for some peoples problems
scott's06 is offline   Reply With Quote
Old 02-22-2007, 07:00 PM   #38
Car: black 06 subaru sti
Fav Mod: anything you can possibly do to a car
IWSTI Addict since: Jul 2006
hey guys its funny because i thought i might have this strut clunk too,because every time i would start to take off as i was letting the clutch out it would clunk...so i decided to have a look around the back and didnt find anything so i looked in the truck and found my jack loose in the mount...the jack was rocking back and fourth making this noise....so check your jacks...
subyguy14 is offline   Reply With Quote
Old 02-25-2007, 06:52 PM   #39
IWSTI Addict since: Feb 2007
I have had and fixed two clunks. The first was the struts, started at 26k very faint. Both rears. Replaced by dealer under warranty at 30k miles. The valving inside comes apart and clunks when the strut extends. The new ones are a new part number but are going to do the same thing according to the parts dept. The second was my aftermarket sway bar endlinks. The spherical bearing were shot and had just enough play to produce almost the exact same noise as the struts. Replaced with stock endlinks clunk gone.
P.S. im now clunk free
rebizap is offline   Reply With Quote
Old 02-25-2007, 07:12 PM   #40
IWSTI Addict since: May 2005
Send a message via AIM to eze13sti
im going to the dealer on tuesday to figure out my clunking noise.
eze13sti is offline   Reply With Quote
Old 02-28-2007, 07:21 PM   #41
Car: 05 STi WRB
Fav Mod: Protune
IWSTI Addict since: Oct 2005
you guys are kidding, right? i must have gone through 6 sets of rear struts already since i bought the car in october 2004. my first clunk occured about 1-2 months after i bought the car.
lubing it is temporary solution, as the struts by design are made to lose the lubrication over time.
subaru needs to do a better job on vendor/product selection process (i.e. bilstein struts for 05 models).
p.s. i just got another pair of rear struts replaced by subaru.
highboost145 is offline   Reply With Quote
Old 02-28-2007, 07:26 PM   #42
lol its funny you say this...i took my car in on tues. to get my clunking fixed....i told him my educated guess what the problem was but i guess he didnt want it..he said it would take 3 to 4 hours to get the problem diagnosed.. ..all you have to do is start the car and go and you hear the clunk.....
Old 02-28-2007, 07:27 PM   #43
Car: Silver 05 WRX STi
Fav Mod: Advan RGIIs
IWSTI Addict since: Apr 2004
I had a similar issue with my car and it turned out to be my axle nuts. They torqued them down and clunk is gone. Worked for me!
mdefalco25 is offline   Reply With Quote
