| Junior STI Driver | I am quite pissed at the moment!!! I purchased the sway bar kit P/N 913240 for the sti and the rear sway is just not fitting - its too short. I have the cobb logo to the outside fo the vehicle, the flat shaped mounting facing the rear of the car for the mounts, the holes for the bushing mounts are parallel to the car. The sway bar is too DAMN short!!! If I mount the sway on one end, its about 1 inch too short on the other. Any insight would be GREATLY appreciated!! Is this even the correct part number for the sway bar kit for the 2005 STI? I purchased it through South Coast Subaru. Thanks OK - here are some picts. I cannot begin to tell you how disappointed I am - but I'm sure you could imagine. The rear of the car is towards the bottom of ALL picts - I was laying under the car with my legs stiocking out the rear. Note how the drivers side appears to be about an inch short - even after all slack from passenger side was used up. The picts tell the story. Has anyone else seen this or heard about this? Drivers side showing the bar being too short ![]() ![]() passenger side (near fuel line and charcoal canister) ![]() This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by 1STI05; 12-24-2006 at 08:54 PM. |
| | #2 |
| Junior STI Driver | I am looking for anyone that has the same problem getting the rear cobb sway bar to fit. Maybe I'm doing something wrong, maybe the bar isn't the correct P/N, or whatever, but I followed the instructions to the "T", The flat tab (with mounting hole) to the rear of the car and the COBB logo to the outside. My pictures match the PDF installation instructions as well. All info is here: HTML Code: http://www.cobbforums.com/forums/showthread.php?p=423534&posted=1#post423534 |
| | #3 |
| Subaru Addict Since 2003
Car: 04 WRB STi - 07 Blue Fav Mod: TIC Click Kit & Cobb SS, RCE Springs and Plates w/Cobb Stg2 Protuned Location: MI Posts: 1,188
IWSTI Addict since: May 2003 Trader Rating: (3) | 1sti05, I cannot see from your pictures. Look at the mounts and make sure they are on the correct side of the car. This is just a suspicion, but you could have the left mount on the right subframe and vice versa. There should be a stamp on the mount showing right/left. For the part numbers, can't you go to Cobb's Website to verify? |
| | #4 | |
| Junior STI Driver | Quote:
When I reversed the install of the mounts, the mounting holes for the bushings were no longer parallel to the car. Finally, facing the Cobb logo towards the inside does not work. Please let me know if I missed any permutations to this equation. | |
| | #6 |
| dances with roads | I took a look at the thread and pics in cobbforum link you provided. Looks to me like Cobb owes you a correct part. This ad is not endorsed by this member. Please register or login to hide this ad. |
