Old 12-20-2006, 10:57 AM   #1
Car: 05 Aspen White Subaru WRX STi
Fav Mod: IWSTi.com
IWSTI Addict since: Jan 2006
Exclamation aligment after new tires??
Hello,
My stock tires are just about on it's way out and need new replacement tires. Called the subaru dealer service mechanic to order in a new set and he tells me that "along with a new set of tires you're going to need an alignment done" is this true?
thanks in advance for your input.
beginnerSTi05 is offline   Reply With Quote
Old 12-20-2006, 11:01 AM   #2
Car: 05 VF34 WRX
IWSTI Addict since: Jul 2006
You do not need a new alignment after getting new tires. If you have not had an alignment done throughout the life of the tires however, it may not be a bad idea to have one done.
wizzman is offline   Reply With Quote
Old 12-20-2006, 11:18 AM   #3
Fav Mod: IWSTi.com
thanks wizzman. i dont want to shell out $100 for something i dont need done. the car drives straight no pulling and even wear on all four.
Old 12-20-2006, 11:22 AM   #4
DC9
Car: 06 Impreza Sti
IWSTI Addict since: Aug 2006
i work at a dealership and also do a alignment with new tires. did the same on my car when i put my snow tires on. if you're pretty good at spotting tire wear you can get by without the alignment but keep an eye on your tires. if not i would just suggest getting an alignment done and make sure they give you a printout with your alignment numbers.
DC9 is offline   Reply With Quote
Old 12-20-2006, 11:40 AM   #5
Car: 05 Legacy
IWSTI Addict since: Aug 2005
Get an alignment. There is nothing worse than buying $400-800 tires and then having them worn out in two months.
$800 bucks down the drain.
BayRain is offline   Reply With Quote
Old 12-20-2006, 01:14 PM   #6
Car: 2008 Pinarello FP5
IWSTI Addict since: Apr 2005
I'd say go for an alignment just because the stock one is poo. Take it to a good shop that can make out negatice camber up front.
- Andrew
RaceComp Engineering is online now   Reply With Quote
