Old 12-10-2006, 05:47 PM   #1
Car: 08 Z06 Corvette
Fav Mod: Jack Jack
IWSTI Addict since: Oct 2005
Default Is this "NVH"?
Hey all,
Got the new Ohlins coilovers on and I love them...
But as soon as I've tried them out, I hear my brakes alot whenever I step on the pedal, especially when coming to a stop. Its a slight "rough sliding" noise coming from at least both rear corners and to a small degree from both fronts.
Is this normal for coilovers with no rubber in the top-hats?
RainMaker is offline   Reply With Quote
Old 12-10-2006, 06:04 PM   #2
Car: 2005 STI (White)
IWSTI Addict since: Dec 2004
Doesn't sound right. I would put the car in the air and double check the installation. Make sure nothing is rubbing, binding, or put on backwards.
Fierysun is offline   Reply With Quote
Old 12-10-2006, 06:58 PM   #3
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
IWSTI Addict since: Jun 2004
Trader Rating: (14)
Is it sort of a pulsating/vibrating noise or more of like a pad friction noise? If it's vibrating you might want to check and make sure the brake lines are secured to the coilover body correctly.
Old 12-10-2006, 08:50 PM   #4
Fav Mod: Jack Jack
Its what I would call a "pad/friction noise".
Theres no pulsation and no change in braking performance.
I've had this car in the air and re-torqued every bolt, and taken apart then re-assembled the brakes.
Still a pad/friction noise. It might well be typical. Dunno.
Old 12-10-2006, 09:25 PM   #5
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
What pads are you running? Sometimes in colder weather the pads just make a bit of noise until they get some heat in them.
Old 12-11-2006, 09:06 AM   #6
Fav Mod: Jack Jack
totally stock.
I should note that as I listened this morning in the rain, it really was only noticable from 10 mph down to a stop. I just happened to be in that kind of traffic for... "sometime".
