Old 12-07-2006, 01:18 AM   #1
286
Car: 06 OBP STi
IWSTI Addict since: May 2006
Default Whiteline 24mm FSB
For the 24mm adj FSB, "This bar is adjustable and allows for the softest setting at 24mm with one additional stiffer adjustment." This additional stiffer adjustment is 26mm correct? Or...?
Assuming it is 26mm, is there anyone out there running a set of WL bars with the front at 26 and the rear at 22? If so, how do you like it? Does it feel balanced or more understeer/oversteer? This is for my daily driver and im worried that the 27f-24r would be a little overkill for me. I dont autox, just spirited driving.
286 is offline   Reply With Quote
Old 12-07-2006, 06:17 AM   #2
Car: '04.5 STi
IWSTI Addict since: Apr 2006
It only has two choices? I thought it was adjustable three different ways?
Old 12-07-2006, 06:23 AM   #3
How YOU Doin?
Car: 2006 Audi S4
Fav Mod: OMGHI2U!
IWSTI Addict since: Apr 2004
Send a message via AIM to jsh139
I run the 24mm fixed front and 22mm adj rear. Without springs, this is really the largest you should go (unless you want wheel lift).
My opinion: for sprited driving, save your cash and get the 24mm fixed (unless you are getting springs, too).
jsh139 is offline   Reply With Quote
Old 12-07-2006, 08:53 PM   #4
286
Car: 06 OBP STi
Sorry i should have mentioned that im going to have prodrives + group n tops before i get the sways... so what should i go for for a daily driver? 26f-22r?
Can anyone confrim if the FRONT 24mm adj sway also adjust to 26 or is it 22 that is the other available adjustment?
