Old 12-04-2006, 05:42 PM   #1
Car: 06 CGM/silver STI
Fav Mod: DIY modding
IWSTI Addict since: Oct 2005
Default Those with cusco sways ...Do you use the stock mounts ???
I am probably going to pick up a set of cusco sways used: 22 mm front, and 22 mm, 3 way adj. rear... I was doing some researching and it appears as if the stock mounts are used (i.e.- there aren't different/cusco ones needed)... anyone confirm this ???
FleaDog is offline   Reply With Quote
Old 12-04-2006, 05:53 PM   #2
HowTo Contributor
Fav Mod: stock FTL?
IWSTI Addict since: Jan 2005
yep cusco bars use the stock mounts/brackets. a lot of bars re-use the stock mounts/brackets.
i had that setup on my car and liked it alot. i switched to the whiteline 29mm front bar since it was what all of the autox folks were using and it's been great. the cusco 22mm rear bar is still kicking butt tho.
Old 12-04-2006, 05:54 PM   #3
thanks bro
Old 12-04-2006, 06:25 PM   #4
Car: AW 05 WRX STi
Fav Mod: Recaro Racing Seats
IWSTI Addict since: Sep 2004
Send a message via AIM to JKonquer Send a message via MSN to JKonquer
yup you use stock mounts. don't forget to get sme silicon grease and grease the bushings before putting it in.
AND DON'T FORGET TO GET SOME AFTERMARKET ENDLINKS. AT LEAST FOR THE REAR. THIS IS A MUST WITH AFTERMARKET SWAY BARS ON SUBARUS.
stock endlinks tend to break or bend with aftermarket or even stock sway bars. fronts have good endlinks and rears don't
I know this from experience since i have cusco sways. and my stock endlinks bent in the rear and it was rubbing my lateral arm and made big o scratch
i really don't know why aftermarket companies offer endlinks with their sway bars, its just a common sense.
JKonquer is offline   Reply With Quote
Old 12-05-2006, 11:57 PM   #5
Car: 05 Subaru WRX STi
Fav Mod: Bride Zeta III / Advan RGII >=)
IWSTI Addict since: Jun 2005
^^^ +1
kartboy endlinks are what i use on mine. good stuff so far.
SD 05 STi is offline   Reply With Quote
