Old 02-27-2004, 06:35 PM   #1
Car: 2008 Fitrari Red
Fav Mod: Getting 40mpg
I'm looking for a comparison between the two and wondering if someone had one, then the other, so we can get some realistic feedback.
Stee is offline   Reply With Quote
Old 02-29-2004, 07:11 AM   #2
Default Re: Road and Track Reader's Choice Best Car 2004..guess who
If no one has switched, then can someone who has driven on the Pinks and the Eibachs please give your impressions. I am going to purchase one or the other in just a few days. Please let us know. We all want the best product.
Thanks
cpturbo is offline   Reply With Quote
Old 03-04-2004, 10:34 AM   #3
Car: autocross, road racing, Bike cruising
Fav Mod: student/design engineer
Send a message via AIM to FasStAsS_sTi
yea same here, i know i read that the eibachs seem to be a little more stiffer in the rear...now im wondering if the drop and the drive is more aggressive with the eibachs or the pinks.... i do like the ride feeling in the stock format
FasStAsS_sTi is offline   Reply With Quote
Old 03-07-2004, 07:38 AM   #4
Fav Mod: stockboy
have any of you called and talked to Eibach, i believe they are one of the companies that like to personally deal with thier customers.
crashsti is offline   Reply With Quote
Old 03-07-2004, 07:18 PM   #5
Fav Mod: Stealth mode
If you autocross, the Eibachs work very well. Aside from redrilled ends on my stock rear swaybar for an additional 15% or so stiffness, Eibach springs are what I just raced with today, and I am not disappointed. I thought I might need an upgraded rear bar, but I can say that at this point I would not change a thing!
Through most of the turns with light throttle, that slight front end drift was still there due to the front diff kicking in, but oversteer never felt more than a blip of the throttle away in Auto mode. The back end only stepped out when I wanted it to, but was plenty willing to do it.
I love the ride, but the balance is what has me grinning.
Snax is offline   Reply With Quote
Old 03-08-2004, 02:13 PM   #6
Send a message via MSN to Silverbane
What i wonder is that the pinks do not drop the car as much as the Eibachs in the front, to keep the car "level". Does dropping the front more (eibach, tanabe etc) springs cause any side effects?
I'm assuming no but I'd like to hear an answer from someone else before I decide also
Silverbane is offline   Reply With Quote
Old 03-08-2004, 02:59 PM   #7
Chuck taught me everything I know
Send a message via AIM to ERacer Send a message via MSN to ERacer Send a message via Yahoo to ERacer
I had the same questions when I lowered my Audi S4. Most factory all wheel drive cars that I have looked at have the front ride height set a little higher than the rear. I doubt it is just for esthetics. I would think it has more too due with weight transfer and handling dynamics as ride height can effect both. Also front end ground clearance. I also find it odd that on most STi’s driver and passenger front ride height is different. Could it be a factory attempt at a little corner balancing? Or is the build quality that bad on the suspension. My only real question would be how much of a handling difference would the additional drop on the fronts with eibachs make on a STi? We really need some back to back comparison of the pinks and the eibachs. If I had to do it today I would go with the pinks and factories larger development budget.
ERacer is offline   Reply With Quote
Old 03-08-2004, 03:36 PM   #8
Car: 05 Subaru WRX STI CG
Default Brake Feel
exactly... levels the car... better spring rate (imo)... cant go wrong for $219 shipped. the pinks are like 257 / 21X or something and the eibachs are around 22x/23x or something... more rear stiffness = good (imo).
Robert~
Old 03-08-2004, 08:10 PM   #9
ahahah lets mix and match and see how it goes, pinks in the front and eibachs in the rear.....=)
Old 03-08-2004, 08:11 PM   #10
btw i am still pondering myself on these 2 plus the stech by tein as well but im gonna shoot myself considering the fact that i wanna feel them before i purchase em, since i hear good and bad about all of them....
Old 03-09-2004, 03:15 AM   #11
Car: '04 WRB
Fav Mod: A working ECU...
My primary concern with lowering is the negative effect on suspension geometry. The stock setup was designed to maximize tire grip (contact patch) in both straight line and turns. Any suspension experts out there concerned about this??
Old 03-09-2004, 04:44 AM   #12
but then why does sti make the pinks? so your statment might not be nesseciraly true vlavetrain.....
Old 03-09-2004, 05:17 AM   #13
Car: '04 WRB
Good point, that's why I wanted to ask the question. I know it's a problem with fully independent A-arm type suspensions, not sure what the impact is on a strut type -
Old 03-09-2004, 09:35 AM   #14
i just know that if i change out my springs im gonna be classified in the street modified and thats fast cars in the scca group...so i might just stay stock for a while and until i can see a drastic change from the stock setup then i may ponder about it....
