Old 12-23-2006, 07:10 PM   #46
Car: 06STi
Fav Mod: cut fenders
IWSTI Addict since: Oct 2005
My two bits if you are to produce a sway bar system:
The bend of the sway leading from drivers side rear mount to the endlink should not pinch the bushing. The bar should have more space as it leaves the mount and bends up to the endlink. The bend should not start the millimeter after it leaves the mount, it needs a "bit" of space. Both Boataholic and I use cobbs adjustable sways and our rear drivers side bushing has been penetrated by the contact of the bar and mount bracket. I've had to replace my bushing as it "creaked" from the bar rubbing against the metal bracket which wraps around the bushing. Boataholic is due as well. I know I'm nit-picking here but I had to say it.
Mexitr0n is offline   Reply With Quote
Old 01-15-2007, 04:22 PM   #47
Car: '05 WRB STi
Fav Mod: whiteline sways ftw!
IWSTI Addict since: Jan 2006
Lightbulb
Originally Posted by ace996
This is the real deal. Ti is 40% lighter than steel, no need to make it hollow...which will cut down on cost, although the Ti is quite expensive raw.
Titanium is sexy stuff but won't work for springs or swaybars. While very strong and lightweight, its elastic and shear moduli are about half of steel. Here's some mechanical engineering for you...
http://en.wikipedia.org/wiki/Shear_modulus
A Ti bar to work it would have to be much thicker than an equivalently stiff steel bar. For a given twist angle, the Ti bar would produce half the torque of the same size steel bar.
As far as my opinion goes, I agree that a packaged setup that works well with the RCE springs would be very very tempting (similar to Cobb but stiffer/more autox & track oriented). It also sounds like a lot of people want a "gap bar" that will fill between the WL 24mm and 27mm bars. Fix the end link angle issue while you're at it
sirdoug007 is offline   Reply With Quote
Old 01-15-2007, 05:20 PM   #48
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
as what a lot have said, hollow bars are the way to go imo...the weight savings are great.
for size, anything bigger than 25 because that's what cobb's are (that's what i use and love them.) but if they're were a bigger size in a hollow sway bar that is strong, i'd be all over it.
VSGTS14 is online now   Reply With Quote
Old 01-15-2007, 05:22 PM   #49
Muller Chevrolet
agree, i looked at mine before and said to myself, "that sucks, they need to give that more room or something"
and like you said it also puts strain on the endlink.
Old 02-24-2007, 09:32 PM   #50
Car: Black 06 STi
Fav Mod: PSS9
IWSTI Addict since: Dec 2006
E.t.a.?
06STiLtd is offline   Reply With Quote
Old 02-24-2007, 10:50 PM   #51
jph
Car: the wagon
IWSTI Addict since: Apr 2004
wow, didn't catch this tread at first
i actually LIKE my Cobb sways and endlinks.
but i could think of a few things that would make me like them even more.
- make the front one JUST A LITTLE stiffer (especially the front)
- make the front adjustable, just like the rear
oh, and sell then at a good price
that's it.
J.
jph is online now   Reply With Quote
Old 04-16-2008, 06:37 PM   #52
Car: 2008 Pinarello FP5
IWSTI Addict since: Apr 2005
Default Re: Gauging Interest,...sway Bars For Sti...
Well we are not done, but here they are. We did not try to recreate the wheel, but to offer something in between in size and address some of the issues we see out there.
Diameter 25.5mm
Solid bars.
Material 4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
washer tabs on front and rear to prevent walking.
Black in color. (unless you guys have a better idea)
More specs very soon. We test fit them today and they fit fine with no rubbing and no noise. Rear is done and just needs to be powder coated. Fronts we have one revision to do.
I am very happy about this and have wanted to do it sooner, but there are still many non modded cars out there and with the new STI here, we arent turning our back on you 04-07 STi owners.
We have 3 beta testers who will be getting these shortly for long term testing. Clint at TIC will get the first set after that and Boost Junkie already has his on ( unpainted at that) for noise testing and fitment checks.
Hope you guys like this. As always I am nervous as its new and I was up in the air about doing this for a LOOOONG time.
More pics tomorrow.
Myles
RaceComp Engineering is online now   Reply With Quote
Old 04-16-2008, 06:45 PM   #53
IWSTI Addict since: Aug 2006
Trader Rating: (15)
Default Re: Gauging Interest,...sway Bars For Sti...( UPDATE ON PAGE 4)
They look awsome. I think Their a perfect balence of what the other companys have to offer. Do you have any idea of what pricing is going to be like?
Old 04-16-2008, 06:45 PM   #54
Fav Mod: Teh Mature Diffuser Will Return!
IWSTI Addict since: Feb 2006
Send a message via AIM to KiR DieseL
I look forward to the results and feedback and i havent purchased a set of sways yet.
KiR DieseL is offline   Reply With Quote
Old 04-16-2008, 06:48 PM   #55
Fav Mod: TiC AST's - 7/6K
IWSTI Addict since: Feb 2005
You forgot guys, like me, who did things wrong and are looking to start over.
Old 04-16-2008, 07:17 PM   #56
Car: 06 WRB STi
Fav Mod: moar boost
How about painting them yellow to match your popular springs.
mEnTaL is offline   Reply With Quote
Old 04-16-2008, 07:53 PM   #57
Car: 04.5 STi- PSM
Fav Mod: learning how to drive
IWSTI Addict since: Nov 2007
I was just going to send you a Pm and ask if these were available or yet. I'l be buying a set of sways/endlinks week week or the week after. I guess I'l have to talk to you about some other options
misterwaterfallin is offline   Reply With Quote
Old 04-16-2008, 07:54 PM   #58
Car: 05 crystal grey sti
We have 3 beta testers...Clint at TIC will get the first set...
Myles
hope he try's them with a set of the AST's...
i vote for black PC. the only time i'll want to show off the color of my sway bars is if the car's on it's roof and i want something to distract the witnesses because of my embarrassment...
kursplat is offline   Reply With Quote
Old 04-16-2008, 07:57 PM   #59
Thanks for the words. I have lost sleep over this at times the whole "to do it or not to do it" thing. Color will probably be black, but if the feedback from the community says something otherwise...we are up for doing what you guys like. I like black because its low key and wont draw attention,plus many other colors are taken already.
Myles
Old 04-16-2008, 08:00 PM   #60
lin the neighborhood of the next competitve brand......nothing crazy.
Myles
