Old 02-28-2004, 07:52 PM   #16
IWSTI Addict since: Oct 2003
No, torque steer is not normal. There was a whole thread on that recently.
My glove box rattles too, but I haven't bothered to try fixing it. Some foam weatherstripping ought to do the trick.
Slowride is offline   Reply With Quote
Old 02-28-2004, 10:14 PM   #17
Car: 2008 Fitrari Red
Fav Mod: Getting 40mpg
IWSTI Addict since: Jan 2004
I have the same problem as well. I attribute it to the spring setup. Just too much weight transfer off the front wheels during acceleration that I think leads to a nervous, twitchy feeling especially around corners. You can feel the car 'push' on-throttle and then bite back off-throttle.
Stee is offline   Reply With Quote
Old 02-28-2004, 10:17 PM   #18
Oh, and I just wanted to add that I have had an alignment at 400 miles on the car and while it did correct the 'STi-factory-pull-to-the-left' as some others have experienced as well, the car still displays the same behavior as stated above. I am now at 1300 miles.
I am positive that springs alone would remedy this.
Old 02-29-2004, 05:44 AM   #19
Throttle-lift oversteer. Yes, it's pretty pronounced in the stock setup. The Cobb front swaybar fixed it for me.
