Old 11-12-2006, 09:04 AM   #1
Car: 06 STI
IWSTI Addict since: Jun 2006
Default stupid question...
don't know a lot about car suspension...a coilover doesn't replace the whole spring does it? and are the cobb springs good for autoX/daily driving
IDAHOSTI is offline   Reply With Quote
Old 11-12-2006, 09:06 AM   #2
IWSTI Addict since: Apr 2005
A coilover is a strut/spring assembled. Hence the term "coil" "over."
Old 11-12-2006, 09:17 AM   #3
Car: 05 STi Silver
Fav Mod: Rumble + Torque = COBB Stg2
IWSTI Addict since: Aug 2005
so yes, the coilovers will replace your entire strut and spring assembly.
The cobb springs might be a bit too low, causing understeer (read about mcpherson suspension geometry to find out why, suspension geometry is a very interesting subject), great for looks, but at a trade off in handling for auto-x. But, sure, you can auto-x without full coilovers, crap, you can auto-x totally stock.
Kirv is offline   Reply With Quote
Old 11-12-2006, 10:09 AM   #4
Car: 06 STI
So from what i read, a coilover setup will handle better then just replacing the springs? What is a good coil over setup to go with for mild autoX and mostly daily driving?
Old 11-12-2006, 11:28 AM   #5
Car: 05 Subaru WRX STi
IWSTI Addict since: May 2006
^^^For mainly daily driving and some autocross, you would be better off with just springs as they will be MUCH less expensive and generally provide a better ride than coilovers (esspecially cheap coilovers). Take a look at RCE, Pinks, or Swifts.
mtskibum16 is offline   Reply With Quote
