Old 11-11-2006, 09:12 PM   #1
IWSTI Addict since: Jul 2006
Default Tein Flex Coilovers Making Clunking Sound?
I put in a set of tein flex coilovers on my 05 sti and now I hear a clunking sound in the rear (not front) when I go over any bumps. everything was installed correctly and is properly tighten, I double checked, and I cannot figure out where the sound is coming from.
anyone have this happen before?
any ideas as to what I should check?
thnx
PhASe
PhaseTuning is offline   Reply With Quote
Old 11-11-2006, 09:35 PM   #2
Car: 05 WRB STi & 07 AW 3
Fav Mod: Invidia G200
IWSTI Addict since: Aug 2006
Send a message via AIM to pj21086
New?? Old?? How old?? It may just be from your rear sway bar.
pj21086 is offline   Reply With Quote
Old 11-12-2006, 08:22 AM   #3
Car: Silver 05 WRX STi
IWSTI Addict since: Dec 2004
Send a message via Yahoo to import111
The more you modify/change the suspension, the more noise you get. My Teins squeek a lot over small bumps, and my swaybars or my brakes or something is causing a loud knocking sound when I slow down or stop.
import111 is offline   Reply With Quote
Old 11-12-2006, 08:33 AM   #4
the teins have a few thousand on them and the car about 20k
Old 11-12-2006, 09:17 AM   #5
Car: 04 WRB STI
Fav Mod: vf36
IWSTI Addict since: Jul 2004
I've had the same problem on my Apexi N1 Type v coilovers. You have to keep the shaft clean. What's happening is that the shaft is sticking as it travels in the strut housing due to dirt and lack of lubricant. Spray wd40 on the shaft, wipe the shaft down and spray again. Don't apply grease to the shaft as some of these threads suggest because it will just attract debris where the seal where the shaft meets the strut housing will scratch the shaft plus the clunking will come back quickly.
calisti is offline   Reply With Quote
Old 11-12-2006, 01:53 PM   #6
Car: 05 Subaru WRX STi
Fav Mod: Bride Zeta III / Advan RGII >=)
IWSTI Addict since: Jun 2005
place the spanner wrenches on the collars and take a mallet to them and hammer away. worked for me. but then the sound comes back after a while. i just repeat and it goes away.
i too thought everything was tightened, but i guess not >=/
SD 05 STi is offline   Reply With Quote
Old 11-12-2006, 02:05 PM   #7
Fav Mod: Exige
IWSTI Addict since: Jul 2005
did you adjust the rear pre load before you installed them?
sti752 is offline   Reply With Quote
Old 11-12-2006, 06:22 PM   #8
I did adjust them all to 8 which is the midpoint I guess so that I could see whic way I wanted to go
I checked my rear sway and its all good
I also cleaned the dampners and the problem is still there
someone told me that it could be that the rears are bad but it seems unlikely that both are bad
I am out of ideas........HELP!!!!!
Old 11-12-2006, 06:53 PM   #9
Car: 2004 STi
Fav Mod: FP Green
IWSTI Addict since: Feb 2004
Send a message via AIM to MauroMotorsports
Have you checked your endlinks? I didn't see any mention of these. If they're stock I know they don't like much abuse. Mine created horrific noises from the rear which could be associated as a clunk too! Might want to look into this, but coilovers DO make some noise. Some get some clunking and others get nothing. It's hit or miss or it has something to do with installation. I think someone mentioned pre-load and that plays a big role here.
Let us know!
MauroMotorsports is offline   Reply With Quote
Old 11-12-2006, 07:12 PM   #10
I disconnected the rear sway and checked the endlinks, I also drove the car with it disconnected and still had the sound
I have been doing some reading and I think it is the preload
HOW DO I ADJUST THE PRELOAD AND HOW DO I KNOW HOW MUCH?
Old 11-13-2006, 08:34 PM   #11
Car: 05 wrx sti
Fav Mod: k-sports
IWSTI Addict since: Jan 2006
Send a message via AIM to slowsti05
my k sports do the same exact thing!!! It drives me INSANE!!!! And sti 752 how do you set the pre load...ive been searching how to do this on the forum and my search came up empty...i kinda remember how to do this from a honda i worked on but i need my memory refreshed.
slowsti05 is offline   Reply With Quote
Old 11-14-2006, 08:56 PM   #12
Car: 05 WRB STi
Fav Mod: PWT Points
I have always had a loud clunk from rear tein's mostly when shifting and always thought that was just related to the pillowball mounts. I also get a slight one going over bumps but have never really cared much about it.
Old 11-15-2006, 05:09 PM   #13
Fav Mod: Exige
You can adjust the preload by moving the top locking perches down you will have to move the entire shock up relative to the green part on the bottom that is bolted to the upright. Look at the manual and be sure to adjust the coilovers to Tein's intitial specs that will provide the greatest benefit as far as comfort. PM me if you have any more specific questions.
Old 11-15-2006, 07:52 PM   #14
Car: 05 WRB STi
Fav Mod: PWT Points
sti752, the way you said your last comment confused me a little. you're saying set the coilovers as tein says in the manual for the most comfort and least chance of clunk?
Old 11-18-2006, 02:36 PM   #15
Car: 04 WRB STI
Fav Mod: vf36
The clunk had come back on my Apexi N1 type v, but finally figured out when it was installed (not by me) that the preload adjustment wasn't done. I didn't know about this since this was my first set of coilovers and until I saw it mentioned earlier by sti572 on this thread. I had always thought why is the spring loose when I have the car on a lift, bad design? No, it wasn't installed correctly! After having these on my car over a year and a half, this was the reason.
This is so the spring sits snug between the two perches so it's not loose even when the suspension is not under load. I just had to loosen the locking ring under the bottom perch, then turn the perch counter clockwise so that it raised the spring up so it sits in the top perch snug without it wiggling between the two. Then to compensate for the height I loosened another locking perch at the bottom of the threaded body and with the perch wrench on the bottom perch I turned the whole threaded body clockwise so it lowered it into the bottom strut mount housing. I took a test drive with several quick left and right turns and some streets I knew with alot of uneven surfaces, no more rear clunking. I report back later on.
