| STI Driver | Hi Everyone, After this long research and wait. I finally ordered my KW V3 for my 06 STi. I am no expert when it comes to suspension setting. But for now. I will lower the STi for the minimal, which I believe is (1.2"F & 0.8" R) Can someone give me an explanation of what the 2 adjustments (Compress/rebond) would do in actual driving? I know people always suggest to keep the setting as default, then change then as it goes..but I don't even know which one to adjust first..! Any recommendation on the setting. eg. 1> softest/most confortable 2> decent on road 3> track The only experience I have on suspension was actually on a 4" lifted Grand Cherokee. I have a 5 adjustable (1 is softest) shocks, which I use 2F/4R to get minimal acceptable soft-ride, and when I go 4 wheeling then it would be 5F/5R. So, from what I understand, it's not like I can just turn them to the softest, as a min setting is require to keep the handling reliable/stable. Thanks EL This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Sold My Soul For Mods Car: '05 CGM STi Fav Mod: Track Time Location: Bethesda, MD Posts: 6,688
IWSTI Addict since: Jun 2004 Trader Rating: (14) | For most situations you will want to keep them at the default settings. For the track you may want to crank up compression and perhaps rebound a bit as well. On the most basic level, the compression (adjusted on the bottom of the coilover) will adjust the rate at which the damper compresses. A higher setting will increase roll resistance, but also result in a bumpier ride. You also have to consider the proper settings to match your spring rates. The rebound is essentially the rate at which the damper returns to its static state after being compressed. Once you get into separate compression and rebound adjustments, suspension tuning can be complicated stuff . Your best bet is probably to start on the default settings and, if need be, make very small adjustments as necessary. |
| | #3 |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,410
IWSTI Addict since: Apr 2005 Trader Rating: (10) | Give me a call and I can explain it to you fast and effectively. Myles This ad is not endorsed by this member. Please register or login to hide this ad. |
