Old 11-07-2006, 08:47 PM   #1
Car: Blue, 06 STI
Fav Mod: Accessport
IWSTI Addict since: Aug 2006
Default Tein Stechs, RCE, Whiteline
So, this is some future planning of mine. This will most likely wait until after I get my stage 2 power fix, but when this time comes I am most likely going for Whiteline 22mm adjustable front and 24mm adjustable rear sways. I would have prefered 27mm in the rear, but I have not found them. Of course, some kartboy endlinks will go hand in hand with them. Anyway, the conflict is now between the Tein Stechs or the RCE springs. I have used Stechs on another car. I was more than satisfied and only paid $124.99 for the whole set! But, I just read a great review on this forum about the RCE springs. I went to their website, but only found other spring brands that they have. Did I miss something? Does anybody know where to find the RCE springs and is there really a whole lot of difference between them and the Stechs? Thanks alot.
WXRTSI is offline   Reply With Quote
Old 11-07-2006, 08:52 PM   #2
Car: RIP 02 WRX
IWSTI Addict since: Dec 2005
:doh:
S-Techs are terrible for anything except car shows.
RCE springs are sold by...
wait for it...
RCE.
Old 11-07-2006, 08:54 PM   #3
Banned
Fav Mod: knowledge
IWSTI Addict since: Apr 2003
Send a message via AIM to Guest_1u53r
get the RCE springs from one of RCE's websites:
www.racecompengineering.com
www.gtworx.com
If they aren't listed on the site, just call them - really friendly people.
Guest_1u53r is offline   Reply With Quote
Old 11-07-2006, 09:11 PM   #4
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
RCE springs by far. and on the sway bars, don't have a smaller bar in front. on the subaru's, you want the bars to be the same size, or the front slightly bigger. i would do 27-29 front, 24-26 rear
Old 11-07-2006, 10:38 PM   #5
Car: Blue, 06 STI
Fav Mod: Accessport
I have read many differing opinions about that. The Crawford sti in SCC ran the larger 27mm in the rear and the 22s in the front. Like I said, this is a daily driver and if I were to go same size front and rear, it would be smaller like the 22mm or maybe 24mm becuase I wouldn't want a super stiff street car.
Old 11-07-2006, 10:44 PM   #6
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
IWSTI Addict since: Jun 2005
Trader Rating: (21)
Send a message via AIM to AndrewSS
S-Techs are junk IMO unless its a show car....
Swaybars, well just get whatever you want, however I believe a big FSB with a slightly smaller RSB is the way to go, granted there are some variables to what decision you should make, but generally I think big FSB and medium RSB is a good idea.
I believe you would find a stock or only slightly larger FSB with a large RSB (anything over the WL 24mm RSB) would be quite oversteery (maybe not make you much faster in autox/lapping terms) then add in RCE springs which have a decent front to rear rate balance = you should have a ton of oversteer.
Personal goals should dicate which way you go so just read around here, this stuff has been discussed A TON!!!
Hope that helps.
AndrewSS is offline   Reply With Quote
Old 11-07-2006, 10:54 PM   #7
Car: Blue, 06 STI
Fav Mod: Accessport
Thanks. Yea everything helps. But the RCE spring alone will not cause a ton of oversteer. I read a great review tonight that the car actually felt quite neutral. Just the springs alone will help solve some of the understeer tendencies, but the mixed feedback about the same size sways versus larger front sways are all opinionated. If I did 24mm whitelines front and rear and rce springs, I the car will have oversteer tendecies. But, a ton? I'm not sure about that.
Old 11-07-2006, 11:07 PM   #8
Car: RIP 02 WRX
Do the springs first. If you feel you need more roll stiffness, add bars on their soft settings. proceed from their to profit.
Old 11-07-2006, 11:09 PM   #9
Car: STI
IWSTI Addict since: Mar 2006
I agree with this. Andrew, do you daily drive your sti? I'm debating wether I should go w/ bigger sways, but don't want to sacrifice ride comfort. I had Buddy Club racing spec dampers on my last subaru, and it was my DD .
ThrillaInManila is offline   Reply With Quote
Old 11-07-2006, 11:16 PM   #10
Car: '06 STI
Fav Mod: air freshener!!!
IWSTI Addict since: Jan 2006
I beat crawfords lap time at streets of willow by 3 seconds last August with my COBB bars. (as reported in SCC's test)
I dont think any sway bars alone can possibly make an STI oversteer.
sway bars wont make your car stiffer over typical bumps like speedbumps, rolling bumps, or expansion joints, but will with diagonal or side loads such as cornering or going up driveways at an angle.
Old 11-07-2006, 11:22 PM   #11
Car: STI
Nice! What other mods do you have, besides cobb's sways?
Old 11-07-2006, 11:22 PM   #12
Car: 05 Legacy
IWSTI Addict since: Aug 2005
I couldn't agree more. I had Cusco 22mm front and 24mm rear up until last night...
I now have the larger whiteline 27-29mm front and slightly smaller rear at 26mm and all I can say is wow.
MUCH and I mean MUCH better.
BayRain is offline   Reply With Quote
Old 11-07-2006, 11:39 PM   #13
Car: '06 STI
COBB TBE, AP, pro tune (300whp w/ 95 octane), brake-man front rotors and calipers, stiffer bushings all around, sparco 5pt harness, Nitto NT01s, Cusco strut bars front and back, battery relocated to trunk. I installed Cusco Zero 2Rs since then which really helped a lot.
And most importantly, a GOOD alignment!
Old 11-08-2006, 10:43 AM   #14
Car: 06 B-SPEC Legacy wit
Fav Mod: AP Pedals and Motons
IWSTI Addict since: Oct 2005
Send a message via AIM to GTWORX.com
Here is the link: http://gtworx.com/catalog/product_in...oducts_id=1338
As all the people have mentioned before the decision between any Tein product and RCE is a no-brainer. TEINS BY FAR!!!!!!!!! lol, just kidding. I would recommend getting the Whiteline 27mm front and 24mm rear. Whiteline DOES make a 27mm rear but is not recommended.
GTWORX.com is offline   Reply With Quote
Old 11-08-2006, 11:29 AM   #15
Trader Rating: (21)
Yeah, but I really dont drive all that much (11-12k miles a year or so)
I dont think swaybars really add that much harshness, they are another way to get roll stiffness without making the car much harsher, granted they have their limitations.
Anyway, one of the big reasons for STi's with big FSB's is the fact that it will help turn-in response and resist our camber curve from going to poop so fast.
I find the balance pretty good the way my car is now.
If you people are really looking to make the car something with only mods I think you are missing some of the point... you have to at some point learn to drive around "problems" IMO - and besides any car will understeer.
Anyway, MY personal top picks for mods if you have autox/lapping/DD use objectives: get a proper alignment, swaybars, springs/upgraded struts.
My opinion for DD cars that rarely see the track or autox, just get what you are comfortable with on the street, and always remeber that besides feel there isnt much of a point about going nuts with mods (IMO) for a DD car that rarely sees the track/autox
