Old 11-03-2006, 09:07 AM   #1
Car: silver 05 sti
Fav Mod: My SIRIUS radio...listening to Howard 100!!!!
IWSTI Addict since: Nov 2005
Send a message via AIM to raginbull74
Default adjusting coilovers..
hey everyone...just looking for some advice. I have the Helix DNA coilovers, and i know the height adjustment is set by the bottom perch, but as far as the upper perch at the bottom of the coil spring you can adjust that aswell. would..i guess..unloading the spring a bit by lowering the top perch and in conjunction soften my dampening work in loosening things up? or are the spring rates the spring rates and i cant do anything about that?! or is the only adjustment the dampening and the springs cannot be adjusted? Just lookin for some answers thanks. Im looking to do this because im going to be doing more mountain/snow driving and such a lowered stiff set up wouldnt be the best. Raising the car back up a bit isnt the issue, just the ride?
raginbull74 is offline   Reply With Quote
Old 11-04-2006, 04:07 AM   #2
Car: Silver 05 WRX STi
IWSTI Addict since: Dec 2004
Send a message via Yahoo to import111
You should not adjust ride hight by using the spring perches. Those are meant to adjust spring preload and corner weights when using scales. Only adjust ride hight buy using the bottom adjustment.
import111 is offline   Reply With Quote
Old 11-04-2006, 04:11 AM   #3
Car: silver 05 sti
gotcha...i actually pretty much found that out today when i was reading some suspension tech on the Whiteline site. Thanks though!
