Old 11-02-2006, 10:57 AM   #1
Car: 06 WRX STI
Fav Mod: Invidia G200
IWSTI Addict since: Jul 2006
Default Flipped front Sway Bar
Is it possible to flip the Front sway bar? I am troubleshooting a problem. I installed swifts and PDE Camber plates. This left the front wheel gap larger then the front. The only thing I can think is that since I had the car on jackstands there is a possiblility the front sway may have flipped.
PS I have Cobb sways and Kartboy endlinks.
boataholic is offline   Reply With Quote
Old 11-02-2006, 10:59 AM   #2
Poor Speed Racer
Car: 96 328
IWSTI Addict since: Mar 2005
i didnt think flipping the front is possible.
are you sure your plates are on correctly? if so are you on level ground?
Old 11-02-2006, 10:59 AM   #3
Car: 2004.5 STi
Fav Mod: Driving School
IWSTI Addict since: Aug 2003
i assume you mean left the front wheel gap larger than the Rear.
I dont know about the PDE plates specifically, but my camber plates raised the front of the car., so i have more of a front wheel gap compared to the rear.
TR11 is offline   Reply With Quote
Old 11-02-2006, 11:21 AM   #4
Car: 06 WRX STI
Here's a pic. I know it's a crappy pic but from the fender to the front tire is about 2 inches and in the rear it is almost flush. I took the Plates off again this morning and they are installed correctly. The springs are also in the correct position. Yes I cut the bump stops approx 1 inch.
Old 11-02-2006, 11:22 AM   #5
Poor Speed Racer
Car: 96 328
wow that pic is bad... so you mean F/R?
check the plates again, you should not be that high in the front.
Old 11-02-2006, 11:22 AM   #6
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
IWSTI Addict since: Jun 2005
Trader Rating: (21)
Send a message via AIM to AndrewSS
that pic kinda sucks to really see much, you can tell the height diff but its not level etc.
I have PDE plates, yeah they raise the front of the car some - and I agree and people have found that left to right in the front there is a bit of height difference.
Your car being an 06 might have different results than my 05, but I dont know.......
AndrewSS is offline   Reply With Quote
Old 11-02-2006, 11:27 AM   #7
Car: 06 WRX STI
Hey Spaze,
Yes front to rear. I'm tempted to take the Plates off and install my top hats to see if the issue is the plates. I took the plates off this morning again to make sure that they are not causing the issue and they are working correctly. I'll take some better pics when I get a chance.
PS thanks for the help guys... I'm bummed out because I spent a lot of time/money and I thought it was going to work out better.
Old 11-02-2006, 11:50 AM   #8
Poor Speed Racer
Car: 96 328
odds are its the plates..... but you'll see when you swap them out.
Old 11-03-2006, 07:18 AM   #9
Fav Mod: Whiteline sways, ohlins coils, cusco motor mounts
IWSTI Addict since: Dec 2005
isn't the front gap suposed to be larger than the rear? the front has taller arches so the wheel can turn.
neal0124 is offline   Reply With Quote
Old 11-03-2006, 10:35 AM   #10
Car: 06 WRX STI
This is the case and I think this coupled with 1/2 inch raise from the PDEs makes it look a little high in the front. I'm just grasping at straws now because I wasn't expecting such a big gap.
Old 11-03-2006, 05:28 PM   #11
Car: 06STi
Fav Mod: cut fenders
IWSTI Addict since: Oct 2005
Boataholic is using Kartboy endlinks front and rear.
Originally Posted by Turninconcepts.com
Which front endlinks are you running?
Mexitr0n is offline   Reply With Quote
Old 11-03-2006, 09:07 PM   #12
IWSTI Addict since: Oct 2004
Did you measure the gap before the install? This is normal. It was always that way.
RBMike is offline   Reply With Quote
Old 11-03-2006, 09:21 PM   #13
Car: 06 WRX STI
Unfortunately I didn't measure before but yes I agree there was always a bit more front gap as is necissary. I'm going to try my front hats this weekend and see how much it lowers the gap then I'll know if the PDE plates are worth it or not.
Old 11-03-2006, 11:18 PM   #14
Car: 06 WRX STI
The Kartboys I bought from you
Old 11-04-2006, 04:04 AM   #15
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
