| Spec C Club
Car: 05 WRX STI - Spec A Fav Mod: Starving my STI Location: Lightweightville, Canada Posts: 1,734
IWSTI Addict since: Sep 2006 Trader Rating: (15) | Well JUST as I was about to order Kartboy endlinks for my COBB swaybars, I ran into this: COBB vs. Kartboy Endlinks - pros and cons? Post 47 Looks like the KARTBOY will not work with the front... so that is out... I COULD get COBB front and Kartboy rear but it doesn't seem to make sense to save a few $$$ when I can just go COBB all around... especially since they have resolved the loose nuts issue by supplying locknuts now. but I'm open to letting you guys talk me out of it before I order in a day or two... are there better options out there? Remember, they MUST work with COBB front and rear swaybars.... which is what ruled out the famous Kartboy ones in the first place. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Amateur STI Driver Car: 04 Subaru WRX Location: Parsippany, NJ Posts: 39
IWSTI Addict since: Jan 2006 Trader Rating: (0) | I had spherical bearing endlinks before with my hotchkis swaybars.... and let me tell you. Unless you want your car sounding like a wooden ship, you might want to consider the bushing type endlinks (aka Kartboys) I had the hotchkis endlinks up front (which were spherical) till the noise drove me nuts. I then switched to kartboys and I and VERY happy with them. You have the Cobb swaybars which are pretty much the same as the Hotchkis swaybars, and the kartboys fit perfectly fine for me. So I', not sure why it wouldn't fit on yours. I cant say whether the rear will fit since I use the C shaped endlinks on my (non-STI) WRX. Last edited by DVN428; 10-31-2006 at 06:10 PM. |
| | #3 |
| Poor Speed Racer Car: 96 328 Fav Mod: Tightening the nut behind the wheel! Location: Northern VA Posts: 8,446
IWSTI Addict since: Mar 2005 Trader Rating: (8) | Why will KB's not work for the front? and why do you want fton endlinks? I've yet to see anyone mess up a front sti endlink. The KB's are cheaper, stonger (or at least beefyer). also lock nuts dont solve the shotty build quality. Nor does it solve the fact that their bearings suck in their endlinks. |
| | #4 |
| HowTo Contributor
Car: 2008 DGM (BBS+Navi) Fav Mod: stock FTL? Location: College Park, MD Posts: 2,155
IWSTI Addict since: Jan 2005 Trader Rating: (9) | Since you're trying to keep the weight down in your car - the Kartboys weight less.* The bushing type endlinks will also make less noise in the long run. * I have no scientifice proof of this. I'm just guesstimating since the Kartboys using a bushing instead of a heavy metal bearing. YMMV IANAL OMGWTFBBQ WAPCE |
| | #5 | |
| Spec C Club
IWSTI Addict since: Sep 2006 Trader Rating: (15) | Quote:
2. Well, according to that guy in post 47, the Kartboys won't work... weird because I thought the COBB were identical to the Hotchkiss bars just a diff. color. 3. Are the C shaped ones only for WRX? | |
| | #6 | |
| Spec C Club
What does "IANAL OMGWTFBBQ WAPCE" stand for? | |
| | #7 |
| Authorized Vendor Fav Mod: Most Copied parts on IWSTI! Location: San Diego, CA Posts: 327
IWSTI Addict since: May 2004 Trader Rating: (4) | What was the problem with our front links? i've personally installed at least a dozen of the front links with the COBB bars. no problems i can think of. Tom |
| | #9 | |
| Spec C Club
If you can convince me this isn't a problem you got my business. I wanted yours in the first place due to the lighter weight. | |
| | #10 | |
IWSTI Addict since: Jan 2006 Trader Rating: (0) | Quote:
| | #11 |
| Authorized Vendor | sounds like their sway bars have some big QC issues as far as length. That is half the reason companies use threaded endlinks to begin with - let's them make adjustments for length as needed. Measure your stock swaybar length, measure your Cobb swaybar length, and if they match, you can use the Cobb. I'd also go ahead and measure the rear to be safe as well. Any swaybar designed to use a stock endlink should be able to use any bolt on endlink The other option if you find the swaybar too short is simply to use 2 sets Kartboy rear endlinks since the rear is slightly longer |
| | #12 | |
| Gold Member | Quote:
http://www.cobbforums.com/forums/showthread.php?t=31609 but the short version is: I went to replace the stock links with the Kartboy links and found that the gap between the control arm mounting point and the end of the bar was about 2 inches per side. The Kartboy endlink with the supplied washers is 1.5 inches wide leaving me with a 1/2 inch gap on each side between the bar and the link. The supplied bolts are long enough to get everything connected so I tried tightening each side evenly to see if the bar had some give but it didn't so I had to put the stock endlinks back on. The Kartboy endlink was the same width and length as stock so I knew it was the right part so I followed up with cobb to see if there was a problem with the bar. | |
| | #13 | |
| | #14 |
| Gold Member | Hey STIGUY88 - Why not take the Kartboy front endlinks off my hands - I will give you a good deal :-) They were only out of the bag for about 30 minutes and are as good as new. I will even toss in one of those nice kartboy decals. |
| | #15 | |
It is not always the case that if the stock endlink fits that any endlink will work. The type of bushing used in the endlink will effect the fit. The stockers have ball joints at the top and bottom and the Cobb have spherical bushings, both of which can accomodate variences in sway bar length and side to side motion. An endlink with a solid bushing requires that the replacement bar is exactly the same length as stock and the endlinks can not move from side to side. This ad is not endorsed by this member. Please register or login to hide this ad. | |
