Old 10-31-2006, 06:11 AM   #1
Car: 08 White STI
IWSTI Addict since: Jan 2004
Default 3rd set of rear sturts - record?
Ok - I had two sets of rear struts replaced on my 04' under warranty. I am going in today to have my 06 replaced. This has to be some sort of record. Fix the damn struts by 08 Subaru.
GotSTI? is offline   Reply With Quote
Old 10-31-2006, 06:25 AM   #2
Car: 2005 Subaru STi
Fav Mod: Cobb Swaybars and Kartboy Endlinks
IWSTI Addict since: Oct 2005
I thought they had them fixed for 06. I already had one set replaced on my 05 and it's sounding like the 2nd set is starting to go bad.
krees23 is offline   Reply With Quote
Old 10-31-2006, 06:29 AM   #3
Car: 05, Subaru Impreza W
If it's the "clunking" your talking about then they are not going bad. They are just noisy. Part of that is by design (inverted strut). Put some grease on the shaft to help reduce the noise.
BlueGold is offline   Reply With Quote
Old 10-31-2006, 06:33 AM   #4
Car: 08 White STI
I'm getting new struts.
Old 10-31-2006, 06:36 AM   #5
Poor Speed Racer
Car: 96 328
IWSTI Addict since: Mar 2005
wow... I have 20K on my 05 and i have yet to hear anything from the struts.... and its not like I've been easy on the car
good luck though on getting new ones.
Old 10-31-2006, 06:40 AM   #6
I guess grease is a good workaround, but if it's 'by design', it seems like it should be clunky all the time rather than eventually getting noisier as time goes on. When I had them replaced the first time, they were leaking oil - they were definitely bad. No oil yet...
Old 10-31-2006, 08:18 AM   #7
Good for you...they will clunk again.
That is my point. New or not they will clunk given time. The struts are actually pretty damn good. However, the design isn't the best (probably cost effective though). IIRC correctly is has something to do with the strut insert being over-extended while at rest and then re-inserting itself into the strut body when in motion. That is the "clunk" noise. Over time the grease wears thin and the clunk is louder.
Old 10-31-2006, 08:31 AM   #8
Fav Mod: FYI, I'm a dude
ohlins fixed perch anyone? if only they weren't, so $$$. got to pay for quality i guess.
Old 10-31-2006, 08:39 AM   #9
Fav Mod: Ohlins struts
IWSTI Addict since: Oct 2006
If I had to guess I'd say that Subaru will go to Bilstein for '08 to better compete with the Evo.
SWortham is offline   Reply With Quote
Old 10-31-2006, 06:20 PM   #10
Car: 08 White STI
That's very interesting. It does seem that repeated hard launching wears on them quicker though.
Old 11-01-2006, 09:34 PM   #11
Car: Silver 04 STi
IWSTI Addict since: Nov 2005
I just grease them every month when I switch my track tires on. Just a little on the shaft and you're good to go. This past weekend, I used marine grease which is water proof.
For a more permanent solution, just get Ohlins. That's what I did. They should be on my car by next weekend.
Risk3233 is offline   Reply With Quote
