View Poll Results: Your stock end links - Bent or not Bent
My end links have bent 82 50.00%
My endlinks have not bent 82 50.00%
Voters: 164. You may not vote on this poll
Old 10-26-2006, 04:33 PM   #1
Car: 2006 - CGM
Default Have your Rear end links bent / flipped?
With all the reports of bent end links and flipped sways, I thought it might be good to get some statistics on number of STIs that have experienced bent end links, vs those that haven't.
For those with bent end links it'd be handy to have:
  1. Number of end links bent, 1 or 2
  2. Springs and sway on the when it bent/flipped
  3. Circumstances around the bend/flip
  4. Miles on your car at the time of failure
  5. Anything else you think is relevant.
Old 10-26-2006, 04:48 PM   #2
Car: 06 STi
Fav Mod: Stage 2
This was on my 04 STi, 06 has had no problems so far.
1. 1 (broken in half)
2. Stock springs and sway
3. Unknown. The car was never tracked.
4. 34,000
5. Audible clunk could be heard from rear when suspension compressed in rear (usually uphill into driveways)
Carciprete is offline   Reply With Quote
Old 10-26-2006, 05:26 PM   #3
Send a message via AIM to AWDfanatic Send a message via MSN to AWDfanatic
I have here are pics.
You can see where it had been rubbing(drivers side)
http://i6.photobucket.com/albums/y216/BRADLEY1997/Picture442.jpg
sorry it's blurry, it's tough getting a picture in this tight area, you can see the broken end of the endlink(drivers side)
http://i6.photobucket.com/albums/y216/BRADLEY1997/Picture441.jpg
You can see that the bar is flipped(passenger side)
http://i6.photobucket.com/albums/y216/BRADLEY1997/Picture437.jpg
passenger side
http://i6.photobucket.com/albums/y216/BRADLEY1997/Picture436.jpg
drivers side
http://i6.photobucket.com/albums/y216/BRADLEY1997/Picture433.jpg
drivers side
http://i6.photobucket.com/albums/y216/BRADLEY1997/Picture432.jpg
20k miles
H&R lowering springs
drivers side broke passenger side bent
will be installing the new bar and endlinks this coming up weekend, and will take more pics then. No wonder I've been hearing clanking in the back.
AWDfanatic is offline   Reply With Quote
Old 10-26-2006, 05:33 PM   #4
Car: 04 STi-sold it
Send a message via AIM to scoob
04 STi
1. both bent
2. JDM pink springs, stock sway bar
3. noticed it a month right after I bought the car, not sure if it was me or PO
4. 15k
scoob is offline   Reply With Quote
Old 10-26-2006, 06:53 PM   #5
Car: 04 WRB STi
Fav Mod: Protune
1. 2 Links bent
2. Stock/Stock
3. Bend was gradual, flip going around corner at low speed
4. 33,000 miles
ender18d is offline   Reply With Quote
Old 10-26-2006, 06:54 PM   #6
Poor Speed Racer
Car: 96 328
1. both bent
2. Swift springs, stock sway bar
3. noticed it as i went in for alignment
4. 12k
5. 05 sti
Old 10-26-2006, 07:10 PM   #7
2 links bent
Tanabe GF210s stock sway
Noticed when jacking car up for work
10K
04 STi
AndyM is offline   Reply With Quote
Old 10-30-2006, 06:01 PM   #8
Car: none
Send a message via AIM to Chiznarles
Just noticed it today! I think it might be related to the fact I was rear ended on saturday.. =(
2 links bent
Tanabe GF210 + Tokico D-spec shocks, stock sway
Noticed when saw one side of car lower than other side
42k
04 STI
Chiznarles is offline   Reply With Quote
Old 10-30-2006, 06:07 PM   #9
Car: 06 STI
I understand bent, but not flipped. Can someone clue me in since mine now give a loud clunk when going up driveways.
STI Tiff is offline   Reply With Quote
Old 10-30-2006, 06:20 PM   #10
Fav Mod: My RallyArmor UR's!!
05 STi
  1. Number of end links bent: 2 rear
  2. Pinks/ stock
  3. Circumstances around the bend/flip: dont know
  4. Miles on your car at the time of failure : under 12k
  5. I could hear something clunk, I think when I would turn.
555BLACKOUT is offline   Reply With Quote
Old 10-31-2006, 10:19 AM   #11
Car: Zohsex
Fav Mod: 295 rears
06 sti
bent while jacking car up for spring install
2k on the car
knew something was wrong from clunks/abnormal handling
replaced with kartboys
kessler89 is offline   Reply With Quote
Old 10-31-2006, 07:06 PM   #12
Fav Mod: JDM STi Performance Muffler
My rear sway flipped and bent both of my endlinks. If you want to see pics check my Journal.
2004 STi
  1. Both of my rear Endlinks were bent.
  2. JDM STi Pinks Springs and stock sways. (Front & Rear).
  3. Took a sharp turn somewhat quickly. Hit a small bump during the apex and then heard a loud thumping. Jacked the car up the next day and saw the flipped sway.
  4. 19,500 miles
  5. Nothing I can think of.
300hp@6000rpm is offline   Reply With Quote
Old 10-31-2006, 07:14 PM   #13
Look under the rear of your car.
Your stock Endlinks should look like this:
Notice how the swaybar is above the lateral link and upright.
Flipped Sway & Bent Endlinks:
Notice how the sway bar is no longer above the lateral link. The Endlink is also wrapped around the lateral link.
Old 10-31-2006, 08:58 PM   #14
Car: 06 STI
Thanks for explaining the flip thing to me. I found out what was causing the clunk. I bought the sway bars from Subaru and the rear bar was too short by about two inches and when I would go up driveways the bar would come down and hit a bar beneth it. Subaru is now trying to find me a bar that does fit.
Old 11-14-2006, 09:01 AM   #15
Car: 05 STi Silver
Fav Mod: Rumble + Torque = COBB Stg2
rear 2 bent. stock struts and sways, jdm pinks. I don't kow if they bent pre or post pink install.
Kirv is offline   Reply With Quote
