View Poll Results: Your stock end links - Bent or not Bent
My end links have bent 78 49.06%
My endlinks have not bent 81 50.94%
Voters: 159. You may not vote on this poll
Old 08-27-2007, 09:52 PM   #46
Default Re: Have your Rear end links bent / flipped?
1. Flipped pass side sway bar, prolly bent atleast 1 link.
2. Stock
3. Car was leaning/pulling to the left on accel.
4. Doing scooobnuts prolly, car has 35000mi
MoNkEyT88 is offline   Reply With Quote
Old 10-16-2007, 07:34 AM   #47
Car: 07 OBP STI
1) 2
2) Cobb Lowering Springs/ Stock Sways
3) Pulling up fast diagonally (to the right) on an inlcined-steep a$$ driveway
4) 3k miles (only about 30 miles after putting springs)
5) Didn't think much of the audible clunk i first heard coming from the rear until i noticed the car swerving to the left while driving the next day. I knew then the first place to look to see what had happened > sway bar twisted (left side down and the right side up) with both endlinks bent
looking to replace both (front and rear) sways and of course the endlinks
any particularly good ones? ( i was thinking cobb sways and wl links)
Mi_Black_Pearl is online now   Reply With Quote
Old 10-16-2007, 07:40 AM   #48
Car: 07 OBP STI
Originally Posted by 05aspenwhitesti_centralnj View Post
I Can't beleive this is a common thing. WTF!! Anyone try getting this covered by warranty. Luckily I have JDM STI Full Pillow Ball Lateral Links and matching end links with the JDM Spec C Type RA 21mm STI rear sway bar going in this week. But damn yo!!!
1. Number of end links bent= 2
2. Springs and sway on the when it bent/flipped= Stock Sway....JDM Spec C TYPE RA 4 way adjustable struts/JDM Pinks/STI Group N tops
3. Circumstances around the bend/flip...No clue, noticed it when replacing rotors and did a search on IWSTI to see if anyone else had this
4. Miles on your car at the time of failure....Approx 35K not sure when it happened
lol im surprised also of how common it is...they made the endlinks just enough to withstand only the pressure of the bone stock suspension setup...otherwise no warranty coverage...no recall
Old 10-16-2007, 07:55 AM   #49
RSV2/BF2142 Player
Fav Mod: Fixing Subie Rattles :)
Send a message via AIM to SiCkSTi04
63k miles and endlinks still look fine
SiCkSTi04 is offline   Reply With Quote
Old 03-19-2008, 02:26 PM   #50
Fav Mod: Access Port V2
2 bent rear endlink back in june 07, now 2 more bent rear endlinks in March 08. Dont buy stock endlinks from subaru THEY SUCK!! I noticed when the passenger side was sitting higher than the drivers side.
St-ill is offline   Reply With Quote
Old 05-01-2008, 11:03 AM   #51
Send a message via AIM to 15secwrx
just found out today when i looked underneath the car....
I thought the struts were clunking and maybe they are, but I think this was the source of the noise in the rear
15secwrx is offline   Reply With Quote
Old 05-04-2008, 06:45 AM   #52
Car: 07 WRX STI
Fav Mod: Matching Dead Pedal
Send a message via Yahoo to cpunlamd
Same thing happen to me. I was hearing intermittent clunking from the rear and just ignored it. The I went to install my TBE and found both rear end links flipped.
The stock end links are VERY flimsy. (I forgot to mention that my end links flipped at about 3,000 miles on my STI)
cpunlamd is offline   Reply With Quote
Old 05-06-2008, 01:52 AM   #53
Car: White and Nerdy
Fav Mod: PayPal !!!
haven't bent mine yet , jack up the car on one side every time i wash it also get wheel lift everytime i pull into the bank parking lot .
Nasioc_STi is offline   Reply With Quote
Old 05-06-2008, 07:40 AM   #54
wdb
dances with roads
The problem is not that they're flimsy, it's that they're too short. If they were longer the bar would never get into a position to be able to 'flip' them.
Old 05-08-2008, 05:06 PM   #55
Car: white,06 sti
came home from work today and noticed the passenger side of the car was higher,looked underneath and didn't notice anything.so i jacked up the car and heard a thunk looked like the endlinks were rubbing on the control arm set it back down and now its level.the endlinks don't look bent though.they must have flipped but now there back.went over a speed bump the other day but very slowly.2006 sti with 10,000 miles.everything on the suspension is stock except for a X brace.what gives?seems like a flawed design
az06sti is offline   Reply With Quote
Old 08-14-2008, 04:38 AM   #56
does anyone know how to prevent this flipping from happening?
kayno is offline   Reply With Quote
Old 08-14-2008, 05:29 AM   #57
Car: 07 OBP STI
my tip is to stays on your stock springs and be careful on making a turn into an inclined drvieway diagonally.
Old 08-14-2008, 06:09 AM   #58
Car: CGM 05 STi
First time going to work with my 05' it happened
1. 1 bent in half, other 1 bent just a little
2. All stock
3. Going through a drainage dip sideways because I was used to doing it in my old car.
4. 25k
5. none
grapejuice is offline   Reply With Quote
Old 08-14-2008, 06:35 AM   #59
Car: 06 CGM STI
Send a message via AIM to mav1c Send a message via Yahoo to mav1c
Mine have not flipped/bent. But that's probably because I switched to Kartboy endlinks shortly after buying the car.
mav1c is offline   Reply With Quote
Old 08-14-2008, 06:52 AM   #60
Car: 06 WRB STI
Fav Mod: Maddad DP/Borla XR-1 Turboback
Sway flipped, both endlinks bent
Prodrive springs / less than 2k miles
26k on car
Pulled into a non level parking space when disaster struck
minorthreats is offline   Reply With Quote
