Old 09-18-2007, 04:34 PM   #241
IWSTI Addict since: Aug 2006
Default Re: All lowering springs (and even stock springs) ride on the bump stops!
Originally Posted by flatthump View Post
Question about Tire pressure and Spring rates Stretch.
I was at a meet and this "suspension engineer" was trying to tell me that every 2psi is the equivalent to 10 more pounds of spring. He actually said "spring rate"
What are your thought on this. I figured the more air psi in the tire, the more energy the spring/shock has to absorb. Leading to mre stroke being used. Which is the opposite of what higher spring rates do.
he was most likely talking about total wheel rate, which includes the tire's spring rate.
homer09 is offline   Reply With Quote
Old 09-18-2007, 04:38 PM   #242
IWSTI Club Level 1
Car: The Spaze Mobile
Fav Mod: Tuning
IWSTI Addict since: Jan 2006
Thats what I though. But most engineers like to use technical language. He said "Spring rate". So I was interested.
Old 09-18-2007, 04:45 PM   #243
well in most engineering books they will use the words "spring rate" for everything (coils, tires, swaybars, etc). simply because everything is modelled as a spring and damper system. therefore, spring rate is the logical word choice, and it is not limited to actual suspension coil springs.
Old 09-18-2007, 04:54 PM   #244
IWSTI Club Level 1
Fav Mod: Tuning
Oh. I learn something everyday here.
But I could have sworn, in the last book I read, "Brilliant Suspension", They used the words "Corner rate" when discussing these things. So as not to confuse the reader I guess. So I dont think everybody uses the word "spring rates" when explaining issues like this.
Old 09-18-2007, 04:59 PM   #245
IWSTI Addict since: Mar 2006
Tires are very complex. The spring rates of a tire aren't even close to linear, so it's hard to generalize them with a "rule". They do have a spring rate, though, for sure.
Edit: I've attached a graph of a 225/45/17 tire @ modeled at 36psi. These are calculated estimates, not actual data.
Old 09-18-2007, 05:05 PM   #246
IWSTI Club Level 1
Fav Mod: Tuning
Well ya.....for every unit compressed (tire compressing), the air-pressure for the following interval raises much more that the tire compressing. It may even be an exponential function.
