Old 09-08-2007, 02:53 PM   #16
Young and restless
Car: 2005 Aspen White STI
Fav Mod: Torque
IWSTI Addict since: Mar 2007
Send a message via AIM to MikeO Send a message via MSN to MikeO
Default Re: Swaybars clunk?
yeah i have the same symptoms in my car.
BUT my suspension is stock. The only thing i have modded is my Down pipe and cobb AP2. The clunking has been going on since i got the car used.
It sounds like it is coming from the driver side trunk of the car. But the noise definitely sounds like a hammer hitting the underside of the car, but coming from the trunk. I thought it was some loose line in my truck just knocking against the metal on the trunk hatch. I have sat in the back seat and it is the loudest that, it also sounds like making something is loose inside my wing. And it only makes the noise when i'm making hard-ish left turns or going over bumps on the left side of the car.
Does anyone think this is suspension related?
MikeO is offline   Reply With Quote
Old 09-08-2007, 04:20 PM   #17
Car: 05 STi - Black
Fav Mod: No Lien
IWSTI Addict since: Mar 2006
check the jack - it might be loose in the holder on the driver side inside the trunk'
Old 09-09-2007, 01:26 AM   #18
Young and restless
Fav Mod: Torque
that's a good call, but i've used it like three times since i put the downpipe in, and when i put it back i put it in tighter than it was when i took it out.
Any other ideas?
Old 09-09-2007, 10:09 AM   #19
wdb
dances with roads
IWSTI Addict since: Apr 2005
MikeO, take a look under the car to make sure your swaybar has not 'flipped'. It's relatively common on STi's and would definitely cause noises. It's also not a great idea to drive the car with a 'flipped' bar because of potential damage to other suspension bits.
Search this forum for more on swaybars flipping, there are a few thousand threads/pics.
Old 09-09-2007, 02:38 PM   #20
Car: 06 STI UGM
Fav Mod: (o)(o)
IWSTI Addict since: Jul 2006
I feel like my popping/clunking is only coming from the front of the car. I have stock endlinks on the front and Kartboy on the rear.
I only get a clunk when going around a corner.
However, should I take the rear endlinks off and grease the metal inside where the bolt goes through?
JAYMAC10 is offline   Reply With Quote
Old 10-02-2007, 10:00 PM   #21
IWSTI Addict since: Sep 2007
I too am having quite a bit of clunking going on lately. Sounds kinda like the underpants nomes have struck up a band in the rear, but occasionally their percussionist wanders up front.On inspection, the rear endlinks are somewhat bent on the Cusco bar, and "at a funny angle". ("It's behind you Tyrone, when you back up, things come from behind!")On closer inspection, the left rear lateral link is also bent, seems to be torque related and not impact.So, I know why mine are making noise, but my question is does replacing stock endlinks with spherical joint ones grant the movement necessary to bypass the clunking, more so than the rigid mounts? Adjustable links should help as well, as running coilovers and aftermaket traction bars changes the endlink angles from vertical, where they should be. Just wanted to be sure before I picked some up with my Sti lateral links.
ikoinu is offline   Reply With Quote
Old 10-03-2007, 08:46 AM   #22
Car: '08 335xi Coupe
Fav Mod: Dinan Reflash
IWSTI Addict since: Aug 2005
After my swaybar install I had clunking too. It turned out to be a loose bolt. In order to avoid excessive noise, make sure those bolts are tight.
